This isn't bodybuilding.com - visual estimation of body fat percentage is completely inaccurate.
Alright sounds good - I'll try and get it check out with a more accurate measurement.
Maybe so 😀, but my guess is closer to 10% than 15%.
Caliper assessment can be really cheap or free at a gym. It's not that accurate, unless you have a highly trained individual doing it. Things like hydrostatic weighing (dunk test) and the bodpod tend to cost a little bit, unless you're enrolled in a university and can get it done in a class. The dunk test used to be the gold standard so it's not bad. DXA scan is the most accurate, but they're like $300-600 if I remember correctly.
i got tested a few weeks through BodyFatTest.com, only 49 bucks and retests are 40. Gave a nice breakdown of various things and some advice on cutting or adding calories depending on goals.
I hite 11.6% but i dont have visual abs which i fully understand is a function of a lot of things .. genes, muscle mass and other items.
If you are under 12% with no visual abs, it's mostly a function of being skinny and weak, or the result you got is inaccurate.
