- Nov 29, 2005
- 242
- 0
- 0
I have AHCI enabled and I have the latest Hard drive and eSATA drivers, but I cant set it to "optimize for quick removal" in device manager, it's grayed out.
Also, it shows up under safely remove hardware, but when I try to remove it, it says the drive is in use and it can't eject it.
It also says it's a SCSI Device, the name is "SATA WD My Book SCSI Disk Device," I dont know if that matters.
Does anyone know how to fix this? I searched online and on this forum, but nothing they suggested seemed to work. Thanks.
Whats weird is it worked when I first installed the intel chipset drivers, before I even installed the hard drive or eSATA drivers. Before that I wasnt able to plug the eSATA drive in while the computer was on. Now I can though, I just cant remove it. I did remove it once when I first installed the chipset drivers tho.
