Alright to try to keep this short as possible. Built a system several months ago. Well the gigabyte mobo went bad(ram slots 2&3 stopped working). So I replaced it with a Asus mobo. I'm running a athlon 64 3000 1gig mushkin ddr400 3200 (512x2) ram. I have a ATI Radeon 9800pro and wd sata 160gig hd.
Well replaced the mobo and now I get errors and will go link dead when playing dark ages of camelot. I have 3 pcs I can play on, none are as fast as this though. Anyway, I can be doing the same thing on all three and consistantly go link dead on my main. I've tested the video card by swapping in a 9600pro card. Reacts the same. I have run over 20 hours of memtest86, ram seems to check out fine. As I stated the mobo is new. Two things at this point I haven't checked, is if there is an issue with the processor(I hope not). The other thing is swapping in a new harddrive. I'm waiting for that to arrive this week.
So what do you think? Will doing a fresh copy of windows help or do you think I should be investigating the processor, or maybe replace ram anyway?
