This is why I'm slightly confused about this HT multiplier stuff. When I dropped the cpu multi down to 4x and the memory to 200 (100) I was able to pump the HTT up to 390 before the board would no longer post. By my calculations that be 1950 which is crazy (95% HTT OC?!?). So does this board automatically reduce the HT multiplier at higher frequencies or is it really capable of producing that high of a HTT frequency?Originally posted by: Geforce man
this is often true, but not always, my VNF4, while a pretty crappy board overall, can take teh 5x HTT up to 260 FSB, and thats like, 1300HTT? it is perfectly stable, but i get more bandwidth @ 3x HTT, so thats what i use for 24/7. who knows.
techfuzz
If I can boot into Windows with an extremely high HTT, I'll check and see what CPU-Z reports the multiplier as. That will have to wait till this weekend though along with everything else.Originally posted by: 5t3v0
That would certainly appear to be the case. I never noticed this happen on mine but then I never left the HT multi on Auto right from the start. What I do remember though, was that when I left say at x4 and went slightly above 250MHz HTT, the board wouldnt post. So it is definately sensitive to HT over 1000.
Just about the clearest set of directions I've read. :thumbsup::thumbsup:Originally posted by: 5t3v0
There's your problem tf. The hypertransport bus (aka LDT) shouldn't exceed 1000MHz (also quoted as 2000MHz because it is a bi-directional bus like the DDR memory bus). The Auto seting sets it to x5 so when you raise above 200MHz the LDT goes above 1000MHz and your system becomes unstable. Set the HT multi to x4 until you pass 250MHz HTT, & then lower it to x3.
As for all the other memory timings, set them manually to their Auto settings at 200MHz (DDR400) just in case they change when using a memory divider. My GeILs did & this caused me issues until I set everything explicitly.
Originally posted by: bwanaaa
this board has an unstable vcore. At idle, usdm reads 1.544 to 1.524v. Temp 37degC. Under load the vcore drops to 1.475 to 1.495. Temp 50degC. What is the recommended solution? I think my overclock is limited by this unstable vcore.
bwanaaa, I use the maximum x9 multi which is lowered to x5 by CnQ when idling & then back up to x9 under load. I have no choice in the multi or voltage it sets. What you say is correct though - if you set the multi lower than default for your overclock, CnQ will raise it back to the default & your PC will crash. In this case you could try using RMClock which is configurable.
Make sure that S.M.A.R.T. is disabled in the BIOS.Originally posted by: Rumple
Ok im at my wits end with this board...My problem is that ANY device except my printer that i hook up to ANY USB port wont detect.
