Hello all!
Im new here. Just want to say these forums kick arse!
I am having an issue with my new system(first build ever). Parts are in my sig. I got everything up and running at stock settings (everything auto). It runs like a champ. I ran memtest overnight and all test pass. I ran 3dmark05 and scored a 7500+. I figured everything was good to go to start OC'ing. This is where my noobness is kicking in. I have prowled the forums looking for answers but I am having no luck so I figured I would go ahead and post my problem. Sorry if my Oc'ing noobness annoys anyone.
When I first got the system built I cranked the CPU freq up to 222Mhz and left absolutly every other setting set to auto. I also realized that I did not have my memory installed properly and it was not running in dual channel mode. The system did clock to 2.0Ghz. I ran 3dmark05 and everything looked fine. I ran it for about an hour and I began to worry about not having something set correctly. I then changed everything back to stock settings. I then installed the memory in the proper sockets and the system was now operating in dual channel mode. I then decided to update my bios. I used the epox magic bios to download and update the bios. Everysince then I have been receing this problem. Is it possible that I have a partially corrupt Bios?
I read the Oc'ing guide and did the following:
I set the Htt to 4x and memory to 166 and started upping the cpu frequency. I also set the memory to 1t timing. I can get to 205 on cpu freq and anything above that will not post. It tells me that the system is operating in safe mode and that I need to change the cpu frequency. I have all other settings set to auto (cpu and mem volt also). Am I doing something wrong? Any pointers would be much appreciated.
