Originally posted by: Stealth4
thanks that does work, but I really wish they had a working US website.
makes me lean toward the MSI board...anyone want to talk me back to the EPoX?
Originally posted by: fanfan
I have slight problem with 9NPA+Ultra, when I switch-on and switch-off my PC, there is one beep, but system boot rocently and WinXp works fine and the whole system is stable. There is a lot codes changing on MB, but it is probably FF. Is it possible to unplug beeping or how can I find the problem? Might it be, that I have no floppy disk?
Fanfan
Originally posted by: DKT
I found another review and it says that the LDT can be set:
http://www.motherboards.org/reviews/motherboards/1547_1.html
There is a screenshot of the bios page (I think it is the 6th screenshot).
I think I found the difference. The Epox manual has the page listed as the "Power BIOS Features", while the screenshot title is "Genie BIOS Setting".
Could there be 2 BIOS' for this board? Could Wesley have done the review with the Genie BIOS?
Originally posted by: sgtdic
DKT, i rebooted my system and went into the bios just for you. i went through every menu and could not find a LDT adjustment. i have an ultra, so i can't speak for the sli. i do not believe there could be 2 different bios's. i think the manufacterer is the only one that makes a bios for their boards. i wouldn't let this sway you from getting this board.
Originally posted by: Azkarr
Anyone using CnQ with this mobo? It lowers the voltage to around 1.18v on my 3000+, and drops the multiplier to 5 (from 9), but it doesn't seem to lower the RPM of the CPU fan. Am I missing something here? I know you can change the fan's RPM with SpeedFan and the SmartFan option in the BIOS, but isn't CnQ supposed to do it automatically?
No. CnQ only lowers the voltage and multiplier, which lowers power consumption and heat production. You need something like SmartFan or Speedfan to then lower the speed of your fan.
