imported_Husky55
- Aug 15, 2004
- 536
- 0
- 76
sgtdic,
I had a hell of a time installing the Nvidia chipset driver 6.66 after I installed the 6.37 from the Epox CD. Others had no problem. Still a mystery to me. Luckily, system restore saved me. I just brought out he big Epox diagram to see what you are talking about NC and +5V. They are opposite of each other. The connector is standard (intel?) so my case connector plug right into it. No problem.
If you still want to install Nvidia 6.66, I found out that after a clean install, 6.66 install OK. I did not install Nvidia IDE or NAM as I had a lot of trouble with NAM.
I noticed that you showed about 2.02 GHz, I think you can do much better that. I also use a tool, Rightmark to underclock the CPU when no load was needed. But I OC when load requires it.
SPQQKY,
I am with mdubrow on this, 5804 did not give me any trouble with shutdown or restart. Although I updated bios after windows and sp2. I did run the beta for a while when X2 support was added and it was stable. When X2 price is more to my liking I will pop one into it.
I have a question for all of you, in your network connection, do you see 1394 as being connected and firewalled in addition to the Local Network Connection (ethernet) ?
I have a rough time installing my HP 2600N network printer. I wonder if it was due to Tor and Privoxy installed and removed previously or something else. I finally plug in another Ethernet card and still have problem. My HP is plugged into the Belkin PreN router.
The funny thing is I have no problem with my laptop using wireless and installing the networked HP printer.
Oh well, another mystery filed for eternity.
SPQQKY,
