herm0016
- Feb 26, 2005
- 8,524
- 1,132
- 126
This particular case had nothing to do with oil or gas exploitation, or building a home. The owners hired an earth moving company to literally flatten their farm, so that from the house they could see virtually all of it. Survey their kingdom, so to speak. In some places, they removed forty to sixty feet of earth and rock. In others, they added up to twenty or thirty. The sulfur could have come from an oil or gas deposit - there are wells for both in this part of Tennessee. But there are not (to my knowledge) any such wells within maybe five to seven miles, and the guy from the state concluded that the problem was that the expansion and contraction of the land (due to removing and adding tons of weight) changed the underlying hydrology. The altered flow of subterranean water both lessened the well's flow and soured it. To my knowledge, there were no conclusions made about the exact nature of the sulphuric deposit(s) encountered, or even whether it was a new source of sulphur or simply a concentration due to the greatly lessened water flow. It was much the same with the pond; its underground seepage stopped, or nearly so. (Although that is much harder to quantify because not only is there no way to capture and measure the flow into the pond, but direct surface runoff was greatly reduced by flattening the surrounding land.) As to intent, that was merely to demonstrate that changes in overlying structures (through any means) can cause disproportionate and unintended changes in hydrology. In this case, changes in stress caused underground streams to reroute. In other cases, fracking causes unexpected results such as flammable and/or sulfuric gases coming into potable wells.
I understand that all this can be modeled, but the ability to model something does not necessarily translate into perfect understanding of or control over that thing.
uh yes? i was demonstrating to others that water well contamination does not only come from oil and gas production. building a house moves tones of earth/adds weight to a spot just like moving a hill does. Fracture propagation is measured in 100s of feet, not thousands or miles. This is why we space wells sometimes as close as a 10 acre circle, or in older fields start drilling in-between the old wells to recover more from the zone. when fracturing, Nearby wells are monitored for pressure. Very rarely do we actually link fractures between wells even less than 1000 feet apart.
link from a reputable source that has proven this? "In other cases, fracking causes unexpected results such as flammable and/or sulfuric gases coming into potable wells"
as above, the case in gasland was proven false before the movie ever came to be, by a state regulatory agency and 2 independent labs.
