Well, I am curious if a powersupply that I am looking at will be sufficient to OC my system.
The powersupply is by Antec so it is a good brand but a little low on the juice its the sl350BLUE. A 350 Watt supply with blue lights. Here is what it will be running:
AMD 2500+ @ 2.4 Ghz
1 GB OCZ platinum 3200 DDR
ATI 9800pro
120 GB Seagate HD
ThermalTake HS/F
2 120mm fans
Thats the basics of it... so, should I upgrade to a higher PS or will the antec 350 watt be sufficient? Thanks for any input!
AMD 2500+ @ 2.4 Ghz
ATI 9800pro
120 GB Seagate HD
ThermalTake HS/F
2 120mm fans
