Markr
Arent the fire extingushers installed fot the type of fire that could happen? Isnt this part of the fire depts job to check that a water extinguisher is not in a kitchen?
The fire extinguishers that have been removed are the ones down hallways and in lobbies, intended for fighting fires in these areas. Usually, these have been water for reasons of cost and efficacy, given the most likely type of fire in these areas.
The normal fire safety recommendation is that individual apartment occupiers keep their own personal equipment to hand. Most domestic extinguishers are of the powder type, which are suitable for most domestic fires.
Generally, if a fire is too big to be easily controlled by a domestic extinguisher, it's doubtful whether people should be trying to fight it themselves. The time would be better spent calling for proper help, and evacuating people from danger.
Remember that these are apartments, and not regular houses. The fire code for apartments is very strict. It's not just the apartment shell that must be fire resistant - the internal walls and doors must also be fire resistant - with every door and every wall, offering a minimum of 30 minutes fire resistance. The idea being that if a fire does break out in a kitchen, you simply evacuate the kitchen, close the door and call the fire brigade. You should have a minimum of 30 minutes before the fire can extend into the rest of the apartment, whereupon, it's spread will be further contained by the next door.
