That's terrible advice. I had a rattling cat for years that otherwise worked fine. Hitting a clogged cat will accomplish nothing.Just hit the cat with a hammer, if you hear any rattling you are screwed, if you hear nothing rattling around its probably not the cat.
Eh, I ran that cat for years and it still passed SMOG check with flying colors.
Cats dont actually do as much as the greenpeace types would have you believe, i passed aircare(our version of smog testing in bc, canada) with a old camero with a 350 and 2 hollowed out cats, as in i cut them in half removed the insides completely 100% and put them back together and on the car. and passed each year with less than 30% of allowable limits. So either the limits are to high or cats dont actually do alot, not thats measurable anyways.
I've known more than one car enthusiast with similar experience. Here's the problem - most people are not car enthusiasts.
If an engine is running perfectly, the FA mixture is dead on the money, it'll burn the fuel cleanly and evenly, and you'll stand a decent chance of passing emissions (especially if they're grading on a curve and allowing higher emissions for older cars and/or trucks. Also depends on the type of test. Some, they're just checking the computer. If the ODBII port says nothing wrong, you pass the test.)
But, if the engine is NOT running perfectly (and hate to say it, but many aren't), it's very, very bad mojo. It's not you the CC is protecting us from, it's that guy who's been ignoring that funny tapping noise for the last 50,000 miles and put duct tape over his CEL.
Evidence: people fail emissions tests all the goddamn time.![]()
I had a plugged cat on my old Firebird, no misfire issues but definite lack of power and wouldn't climb to higher RPMs. Made it tough to drive since it was a stick. Also smelled like rotting eggs, notice any odd smells from the van?
OP: After reading the thread, I am pretty convinced what 96Firebird wrote is your problem.
Youtube has a few great vids that show you how to check without buying anything. I would review them as well. Otherwise you could take it to a decent muffler shop for an inspection.
In case it wasnt obvious i meant a rubber hammer i didnt think i needed to specify that but i guess i should have....
And if your cat is rattling its a ticking time bomb, period. That means the inside components(which look like small balls about golf ball sized) are loose and will eventually plug it up, a brand new cat has nothing loose inside of it and isnt supposed to ever have loose components inside of it. So finding out if its rattling will indeed accomplish something it will accomplish letting you know your cat is either good or bad in a very fast and simple manor.
Also Most of the rattling people hear from there cats are not actually the cat but the heat shields so also keep that in mind.
Huh? I've never seen a catalytic convertor with 'golf ball sized balls' in it. Every cat I've seen has a linear ceramic substrate. Can you link to a picture of one like you describe? I'd be interested in seeing it.
I ended up taking it to a muffler shop. It was cheaper than any of the small list of CARB approved ones I could find online. It ended up being a reasonable $250.Most of them are either pellet or honeycomb types. And if you should need a new one, Magnaflow makes replacement High Flow converters that are legal ijn most states. I think they also have some with CARB certification for California use.
Nah there are actually markings on the cat with the specific serial that needs to match in their database or you won't pass smog.That's a pretty good deal. Nobody will ever know if the sucker is CARB approved. It's just a racket by the state to collect more fees.
Indeed. It included quite a bit of cutting and welding.Well $250 parts and labor is a reasonable price.
I failed smog before when the smog guy checked and found my cat had an executive order that was rescinded. https://www.arb.ca.gov/msprog/aftermktcat/aftermktcatdbase.htmNobody will ever check for those markings. Seriously.
https://www.catalyticconvertersonline.com/x-how-a-catalytic-converter-works-1
Top pic, pellet type. The one i cut open probably had 200ish of them left, looked like it could have had 2-3 times that many originally some had disintegrated.
