I agree that the motor mounts for that car SHOULD'T need replacing yet. Which Altima model?:
Altima 2.4 GLE
Altima 2.4 XE/GXE
Altima 2.4 SE
Automatic or manual transmission? Does make a BIG difference in parts prices...
From Zygmunt motors, (one of my BMW parts suppliers using the XE/GXE for reference)
http://www.bimmerparts.com/index.html (I've done a lot of business with them over the years. VERY good parts source)
Manual Transmission:
Right (fan belt side)
This is the engine mount at the front of the engine block (RH side of the engine compartment). The bracket attached to this mount is not included (reuse or order from the dealer).
A7000-128741 Engine Mount IN STOCK $151.55 $47.44
Front (radiator side) for models w/ M/T
This is the engine mount located at the front of the engine compartment. The bracket attached to this mount is not included (reuse or order from the dealer).
A7000-128707 Engine Mount IN STOCK $63.77 $16.05
Rear - Firewall Side for models w/ M/T
This is the engine mount located at the rear of the engine compartment. The bracket attached to this mount is not included (reuse or order from the dealer).
A7000-128732 Engine Mount IN STOCK $94.32 $16.05
Automatic Transmission:
Front (radiator side) for models w/ A/T
A7000-128710 Engine Mount Corteco/Freudenberg IN STOCK $63.77 $34.24
Rear - Firewall Side for models w/ A/T
A7000-128742 Engine Mount IN STOCK $94.32 $69.39
Prices listed are: first=retail 2nd= their price
