Originally posted by: KokomoGSTmp
Freeze plugs do not protect the block... I've never seen or heard of anyone melting a freeze plug. I've heard of them leaking... never melting.
Of course they protect the block, why do you think they're called "freeze plugs" ?? I don't doubt that they serve secondary purposes as well, but pretty sure that's how they get their name. (so if you have water instead of coolant in your engine, and it freezes, they are pushed out to (try to) prevent more serious damage.
I agree with everyone else that they don't melt under any sort of normal condition (at least all the ones I've seen are metal) - however it is not unlikely for them to leak. And if your cooling system has "mud" in it, then it seems reasonable that this same glop is what is dripping down the side of your engine.
The freeze plug itself probably costs all of $4, however labor could be $$ depending on how hard it is to get to. (I believe it is simply a matter of yanking the old one out and hammering a new one in)
Now what you didn't mention is how much you are willing to spend, where this particular freeze plug is located, etc. You also didn't mention if you are the first owner of the car, which I doubt. And if you aren't - the coolant could be more stop-leak than antifreeze at this point. All kinds of muck can build up in a radiator after 13 years of no maintenance. What you SHOULD do is replace the freeze plug, have the radiator and cooling system flushed and possibly the radiator replaced if that yields problems, and then go from there to see how the rest of the cooling system is... however, add that plus the A/C problems, it might be cheaper to go buy another 1992 LeBaron!
PS: For $6 you can probably get a brass freeze plug which will last longer
Edit: I take it back, apparently there is quite a bit of debate about whether or not "freeze plugs" actually started as protection against freezing or simply as casting side-effects - however they certainly go bad on a regular basis and if there was not SOME intent to use them for freeze protection - it would have been a lot smarter of them to make a threaded plug instead.
