- Dec 18, 2010
- 18,811
- 197
- 106
They're also not supposed to be plugged into cubicle power rails.
Nobody said this was in a cubicle.
Do you have any idea what the power draw on space heaters are? We couldn't even plug those in in the winter while in the field, they would cause all sorts of problems with the generators and I plugged one into an UPS that ran a ton of gear, no load and just turning on half of the space heater pulled over 70% load on the UPS. I stopped giving the generator guys a hard time and continued to freeze after that. Space heaters are the devil!
Do you have idea how cold it is in space? I wouldn't want to lose power to my heater either
Just general 'do not bring heater to work' info for you..
I don't quite understand. If the UPS was plugged into the wall and the grid was powered, it shouldn't have drained the batteries.
It was probably just complaining about the excessive load.
Even when it's running off the wall, the UPS could still identify that there's an excessive load on its battery-backed outlets, and start complaining.
thats why we have UPS's that have a surge only side as well as a back up side. makes it much easier to use small tools, laptops and what not without taking load from the battery side.
OP, was it the old kind with exposed heating elements or the new kind that heat oil.
I wasn't paying attention once and plugged a vacuum into a power strip that was connected to a UPS. Doh!
As for a space heater, it depends the wattage. I've plugged a 550 watt space heater into a small APC UPS just to test it. In fact it's a great way to do a load test, see how long it runs on the battery. Add a light bulb too. A 1000va UPS will do about 600 watts.
You're not supposed to plug a heater into a UPS? You make it sound like everyone should know that.
She.
did she do that because the UPS peed in her front yard?
