Employee plugged space heater into the UPS
Texashiker
18,811
198
An employee just called and said the UPS is beeping.
Come to find out, she plugged a space heater into the UPS. D:
amdhunter
23,332
249
My XBOX wouldn't work through a UPS either. Pissed me off since I have the console that's on a line with an AC that blows fuses every so often.
M0RPH
3,302
You're not supposed to plug a heater into a UPS? You make it sound like everyone should know that.
IndyColtsFan
33,655
688
I wasn't paying attention once and plugged a vacuum into a power strip that was connected to a UPS. Doh!
M0RPH
3,302
So what's the lesson here? Don't plug in things that use a lot of electricity?
Nintendesert
7,761
It will do that if the UPS is plugged in?
Do you have any idea what the power draw on space heaters are? We couldn't even plug those in in the winter while in the field, they would cause all sorts of problems with the generators and I plugged one into an UPS that ran a ton of gear, no load and just turning on half of the space heater pulled over 70% load on the UPS. I stopped giving the generator guys a hard time and continued to freeze after that. Space heaters are the devil!
ElFenix
102,407
8,595
did she do that because the UPS peed in her front yard?
SP33Demon
27,928
143
A good UPS will show what % capacity it's at.
And FYI you can run small space heaters off the more expensive ones. Your company is cheap.
Exterous
20,612
3,834
Do you have idea how cold it is in space? I wouldn't want to lose power to my heater either
Oct 20, 2005
10,978
44
I think he was asking if the UPS was plugged into the wall, wouldn't the space heater just draw power from the wall and not use the stored energy in the battery of the UPS?
Lithium381
12,455
7
space heaters do blow fuses...... i've done itmany shares of time.... i just gave up and put on three sweatshirts
Jeff7
41,596
20
Even when it's running off the wall, the UPS could still identify that there's an excessive load on its battery-backed outlets, and start complaining.
The trick is to watch what else is on the circuit. Spaceheaters typically max out at 1500W, so 12.5A. That doesn't leave much room for other stuff.
Some have a lower setting that might only be 750W.
12,960
Those things have NO place in an office environment... They're dangerous, especially for the typical person who reverts to a 5 year old once they walk into their place of employment. I've seen two fires from them, both were from leaving the heater underneath their desk and on.
They're also not supposed to be plugged into cubicle power rails.
Feb 25, 2011
16,998
1,626
...and you really, really shouldn't be using a heater in a network closet. I mean, how much money do you spend on HVAC for those things in the first place?
lxskllr
60,792
11,139
Aside from the physical technical issues, plugging a heater into a UPS will remove its capability of doing its job. If the power drops, the heater will suck all the reserve power out, and not leave enough time for safe shut down of the computer.
