electric toothbrush without a battery
A hydroelectric toothbrush is the future. Let the water from the faucet spin a generator to power the brush.
Now that I think about it, how about a turbine in the main water line. Generate power from every flush, shower, etc.
Ooh! a poopy turbine! my favorite type!
Doable, but probably not worth the effort. There's not a lot of head in your sewage pipe.
Not in the waste pipe. In the main water line. A small setup is probably too expensive for how rarely the water runs in a home. But I do wonder if it would work at a municipal water plant. I'd guess they have a pretty steady flow of water.
err, municipality spends money pumping water up to a water tower to pressurize the water and you are asking them to do what?
I have one that you just shake to recharge. I just go ahead and put toothpaste on it and stick it in my mouth while I shake to charge it. By the time I'm done charging it, my teeth are clean.
You win a cookie, make sure you brush your teeth afterwards though.
lol, I'm not saying it will create as much energy as it takes to pump it up there. But the money spent to pump the water up there is a sunk cost. It's getting pumped up there anyway. Why not capture some of that energy on the way back down.
