funboy6942
- Nov 13, 2001
- 15,368
- 418
- 126
http://img85.imageshack.us/img85/9936/truckside3sf.jpg
I am using firefox and it is working fine. As for prices I already posted that, check out the quote
All I run in is grass. Keep it short and you wont have any troubles or shorter run times. Mine are 20+ in grass. No the truck doesnt come with A brushless set up. It comes with eother a manual esc or electronic. Since swapping out the esc and motor for a brushless then get the manual esc since it is cheaper and everythign else is the same.
if you want dirt place check out a ball field. Just be nice and dont go driving it there before a game and they have the chalk lines looking all good. Pick up some ramps. Walmart sells scate board portable ramps which work great. If there is a local BMX track check there for jumps and dirt. Check out some rc mags as they will ahve in the back local directry for outside and inside tracks. And again IMO the stamp is a perfect choice for it opens many options to you to run it as a stadium truck, and monster truck, or even a car with little to no heavy modding. Plus there are hop ups a plenty. But running it in the grass the way I have it set up will give you 20 min runs and if you want to pm for exactly what I have done to my truck Id be happy to let you know. Its not a cheap hobby but it is a fun one and you could spend your money on worse things. Just do it right. Dont run Nicads. Yes they are cheap but you will only see 5 min max and that kills it for alot of people trying to get into the hobby. The Epic batts I mentioned and a good charger will make a world of diff. If your pockets are deep then go for even better batteries and longer run times. But there you go a starter for electric.
