- Jan 23, 2007
- 211
- 0
- 0
First off, can it be installed inside the tubing?
How much heat would be introduced?
Crazy question I know, but my friend had the crazy idea of introducing it into the system through strategically place tee fittings.
Probably look awesome, but is it safe or would it add a ton of heat?
Yes it would displace coolant, but there would still be more volume in a 1/2" line with the EL than a 3/8" line.
Thanks,
Rob
Thanks,
Rob
