Eh what the hell...UPDATED WITH CARD IN COMPUTER
implicit1
153
I also flashed an Ultra BIOS, and it also helped me quite a bit. 366mhz would show artifacts on the LE BIOS right away. With the Ultra BIOS I've tried up to 435mhz which didn't have any artifacts after 1 loop through of 3dmark03. It was also kind of funny to see the auto overclocking "feature" in the ultra driver set the clocks to 435/1.16. Anybody know what it looks for when Auto overclocking??
THUGSROOK
11,847
yep
update: im now using a moddified eVGA 6800GT bios ~ much faster then the moddified Ultra bios i was using. (check my thread)
aonic
139
damn, o well i want to keep this card for the next 2 - 3 years atleast so i guess flashing wont be for me ;(
lordfreddy
9
Folks, I just flash my 6800 Limited edition to the regular Ultra. I used nvflash 5.10 and eVGA 6800 Ultra Rev.04 bios. The card is running @ 425/1101 now, with 54C idle and 71 loaded. Through the process of flashing the bios, I learned that the hardware ID of this card is 0040, which is the 6800 Ultra ID, but it seems that eVGA strapped the EEPROM down to the 6800NU ID, which is 0041; you can verify this by opening the Rtuner 15.2 diagnosic report. Mine was: Hardware ID: 0040(Rom strapped to 0041), and now after flashing, it becomes to 0040(Rom strapped to 0040).
Zahriya
178
Can you guys explain for us NOOB's how you're doing all this. Id be interested in trying to upgrade my bios to fix my problem
aonic
139
quick question: lets say I upgrade the bios and it doesnt work out.. its still possible to change it back right? I know it can be done with my motherboard's BIOS.. the only problem with the video card bios i see is that it doesnt display and if i cant see i cant reflash :p
THUGSROOK
11,847
the GT rev01 bios is faster ;)
the bios files i offer in my thread also have 1.5v gpu cores and are specificly tested for the eVGA 6800LE.
take a looksee and try my LE-GT bios, youll like it.
(rom strap is 0045 for a GT)
lordfreddy
9
Ok. Here is how I did it; first, go get the nvflash 5.10 from http://www.guru3d.com/newsitem.php?id=1998, then get the lastest eVGA 6800 Ultra bios from http://www.mvktech.net/index.p...older&filecatid=51 (there are Rev.1-4 eVGA 6800U bios available to download there, but I used the latest one, which is Rev.04). Once you got both, make a DOS boot disk, then copy the nvflash and bios to the disk. Then reboot the comp.
Once you reboot, and go into <A:\>, you first type in "nvflash -b <filname>.rom" to BACK UP your original bios, then you type in "nvflash -5 -6 <filename of the new bios).rom", then your 6800 limited edition will be flashed to 6800U with 425/1100 setting. Beware that you will have to use the "-5 -6" command to force flash the bios to your card; your 6800 limited edition was force strapped to 6800NU by eVGA initially, if you use the regular common "nvflash <filename of your new bios>.rom", the nvflash will respond with something like hardware ID doesn't match and subsystem ID doesn't match, and your card will not be flashed. Once your is flashed, reboot your comp, reinstiall 66.81 driver, then you got yourself a regular 6800U. So, good luck to whoever are trying to do this, and enjoy your new card!!!
WARNING: I am NOT responsible if you screw up on this, and PLEASE Back up your original bios (by type in "nvflash -b <filname>.rom") before you do the 6800U flashing.
jrhea
Okay, so what's the general consensus here now? Is this a good deal or not? Get this or a normal GT?
Thanks for everyone's hard work on this!
Wag
8,288
8
If someone wants to really do a public service, could they create a boot disc image that will backup and update the bios with a single keystroke?
That way if someone screws up totally they can restore their old bios without seeing anything.
So something like:
Press
"1" update to new bios
"2" restore original bios
Cannabis
155
Just flashed to the evga ultra rev. 4 bios. After flashing I noticed that it defaults to 425 with that bios.
3dmark 03 12,091 @ 425/1100
3dmark 05 5,000 @ 425/1100 max temp - 71
5,045 @ 435/1100 73
5,194 @ 450/1100 74
Screenshot
Thats a 125mhz OC one the core. It may go higher but I dont want to risk my card as I now very pleased with it 400/1100. I can only push the ram up 1150 befor I start to get artifacts and lockups so I'm just going to leave it stock. I feel bad for anyone that missed out this deal.
Gandolf1
22
Excellent!!!!!!!!! worked perfectly. just follow the directions. I renamed the ultra file to a shorter name just for convenience
G
Wag
8,288
8
Hmm. I flashed successfully to Ultra but still no good.
I wonder if it's my Power Supply? Antec 400 (regular) should be enough, shouldn't it? The fact that my card is locking up default timings with normal bios isn't good.
Think I should exchange for another?
aonic
139
its gone :p out of stock! limited edition
WiseGuy282
4
Try ebay. There's a guy on there selling these, but for about $40.00 more than new egg. Mine get's here on Monday.
ronach
Well, this is getting exciteing, now we have some guys overcomeing the bios problems, great work gents. Now all we need is some guy to find a schematic for this beast, and the rest of us can go to work on the hardware. This is almost as much fun as doing Ham radio stuff.
aonic
139
ya, im gona wait a week or so and see other people's expereince before i jump on the wagon :) nice work guys
Vallybally
259
Couple concerns:
- Just cause this new BIOS seems to unlock the true Ultra on this card today, can we assume it will be fine and stable a year from now? (I guess I just can't understand why eVGA would willfully sabatoge some of their perfectly ok Ultras with a crappier BIOS to underclock them...)
- Why is Thugs getting better results with the GT BIOS rather than the Ultra? Which is better....
Killrose
6,230
8
If this turns out that these will do Ultra speeds with a bios flash, and were only crippled because of a marketing gimmick, this is great news and i'm glad I bought the very last one that Newegg had :)
But i'm not too hopeful its gonna run on my Antec 350watt Smart Blue PSU, especially at Ultra speeds :(
