Looked into these a while back and seemed to be very effective (and expensive). The problem was that there was a small part that would break after a couple of years and you couldn't get it replaced. YMMVYou want an LP powered mosquito trap/magnet. Your local home improvement place carries them. They work.
Links?Try catnip. It's the most effective mosquito repellant. It's easy to grow, and your cat will love you.
low pressure
long play
lumbar puncture
low power
we had an earlier thread on mosquitos and electric zappers. some good info in there too.
Not if you've never heard of it, as a person who needs the suggestion probably hasn't. Even after learning of the device here, I still don't know how it's supposed to work. What does the propane do? Generate heat that attracts mosquitoes? Can't see that being too effective compared to other methods, but I guess it is.
Cat was getting eaten alive.
Mosquito's can penetrate a cat's fur? :hmm:
