- Jun 25, 2004
- 5,530
- 141
- 106
Looking to do some audio upgrades on my Honda Insight. It's currently very "cobbled together".
What I have:
Two cheap Sony 40w RMS 6.5" speakers in the doors, powered by head unit, came with the car.
Two cheap Rockford Fosgate Prime 45w speakers I added to the deck behind the two seats
A Bose home subwoofer I found on the side of the road with a dead amp (which I cut off), under the carpet in the hatch - looks a lot like this.
A 240w RMS Kenwood 4 channel AB amp (KAC-8401) I brought from my previous car, powering rear speakers and sub
85hz Crossover
Dialed back ~1500hz range by head unit's equalizer due to it being way out of line from the front speakers
The rear speakers sounded significantly better than the fronts when all of them were powered by the head unit / before I found the sub, to the point I almost didn't want the front speakers. I'm not sure if this is because of the better "enclosure" provided by the deck vs the doors, or if it's the speakers themselves, but that's why I chose to put the rears on the amp with the sub. I couldn't change the fronts out at the time because the door panels prevented anything but a low profile speaker from being installed, but that's resolved and I can install whatever now.
The sub sounds "fine". I'm not a bass head, I listen to a lot of indie and acoustic music and tend to keep the bass low enough that it fills in, but doesn't overwhelm. It serves this purpose, but I'm open to thoughts/criticism.
Over the weekend I mounted my door speakers to the door frames, rather than to the plastic panels, and that seemed to improve the very anemic upper base the fronts provide and mellow out the overwhelming 1500hz +/-.
At this point I'm not sure what would be the most cost effective way to make it sound a little better. A friend would be willing to sell me his class D Alpine PDR-F50 amp for pennies on the dollar. On paper, aside from more watts and an original price tag 4x as high, it looks to have worse THD, signal to noise and frequency response than the significantly cheaper Kenwood amp I already have. I understand class D amps are more efficient, and what's on paper isn't always reflected in the real world. I'm not sure what I'd do with two 4-channel amps. I'm considering swapping the Kenwood out with the Alpine for the door speakers (and throwing it up on Craigslist) to see how it sounds, and then either dedicating the Kenwood to the sub, or replacing it with a small 1/2 channel D amp for the sub.
Regarding the sub, I would consider replacing it with something a little larger, but I don't want a terribly large sub. I believe the Bose unit has a 6.5" woofer, maybe an 8"?
I've looked around at replacement 6.5" door speakers. A lot of reviewers and sites seem very reluctant to call one speaker better than another, and instead imply buyers should just listen to them. That's hard to do when ordering online. It seems like more expensive speakers tend to have higher RMS watt ratings but otherwise look no better on paper, and frankly I have little first-hand experience with car speakers, so any specific suggestions would be helpful. What do I need to know when selecting door speakers? If I were to order today, I'd likely try out some Infinity Reference speakers.
Thoughts on putting a few strips of dynamat knock-off into the door panels?
Other ideas?
What I have:
85hz Crossover
Other ideas?
