- Nov 27, 1999
- 65,463
- 408
- 126
More Style, Less Room
Available in two body styles ? coupe and sedan ? the new 2006 Civic is offered as four distinct models: the Civic Coupe, Civic Sedan, Civic Hybrid (sedan only), and the racy Si (coupe only). The hatchback body style, which was exclusive to the previous Si, is a goner.
For the first time, the coupe and sedan don't share a wheelbase. Honda's engineers felt the sedan's new 106.3-inch wheelbase was just too long for the coupe to feel as sporty and responsive as they desired. So while the new sedan's wheelbase has grown 3.2 inches over last year's, the coupe's is only 1.2 inches longer.
Even with the longer wheelbase, somehow the coupe has lost 2.5 inches of rear-seat legroom. Meanwhile, in the name of styling, Honda's designers sacrificed some rear headroom. The new coupe's roofline is several inches lower than its predecessor's. Combine that with the car's radically fast backlight, and those with large craniums should ride in the front.
"True coupe buyers will sacrifice a little rear-seat room for better performance and sexier styling," says Greg Thomas from Honda's product planning division. "But you can still sit full-size adults back there very comfortably."
He's right, you can.
The sedan's rear-seat room is about the same as before, and both body styles gained 1.4 inches of additional width, so sticking a third in the backseat of either no longer qualifies as bad karma.
Due to the shorter rear overhang, trunk space also took a hit. It's now 12 cubic feet in the sedan and 11.5 in the coupe (both used to be 12.9). But Honda points out that the trunk sides are now flatter so the space is more useful. And the rear seat in every model but the hybrid folds flat to increase cargo space.
Edmunds First Drive: 2006 Honda Civic
