Similar to a turkey baster, but with a tube attached? Or even a syringe. The stingray is going to the track soon, and I need to get something to remove the excess oil after the weekend with. It's a dry sump, with a reservoir, so it's easy access to remove some.
Or will a plain plastic turkey baster be fine?
EDIT: Moot point. I was getting the wet sump instructions confused with the dry sump. No extra oil is needed.
