- Jun 1, 2001
- 38
- 0
- 0
I recently bought this board from newegg and am having trouble with it booting up. After changing some BIOS settings, the system will not boot. I have tried to clear the CMOS memory on jumper 4 with intermittent success. I leave the jumper on 1-2 for a few seconds, nothing happens......leave it over night, nothing happens......leave it that day & it starts up. This has happened twice. After the first time, I left it run at the default settings. It ran flawlessly for a week. Went to change BIOS settings again & the system would not boot. Tried to clear CMOS as stated above for a day and a half and it booted up. Shut it off and replaced side case cover & connected all peripherals and now it has been 2 days of trying to clear CMOS memory & will not boot. I have tried to use the power & reset buttons as some have mentioned with no success. I tired replacing the battery with no success either. The only thing left is to completely remove everything from the board which I am going to try tonight if possible. If this does not work, any other suggestions besides returning to Newegg. Also, looking for suggestions as to either seeing if Newegg will send another one or purchase an entirely different board (any suggestions on a comparable board). I already have SDRAM so would like to stay with it. On board sound is OK and LAN on board is not a neccessity as purchased a card to run an older computer.
Current configuration
Antec Mid Tower w/300 PSU PP-303XP
Duron 950 mhz
512 MB Simple Tech PC133 memory
Maxtor 20GB HD
ATI Rage 128 Pro 16MB (not a gamer)
PCI modem (generic)
SIIG 4port USB PCI card
Lite-On 52X CDROM
Teac 16X burner
Duron 950 mhz
Maxtor 20GB HD
PCI modem (generic)
Lite-On 52X CDROM
Teac 16X burner
