I know this will probably be too easy for you guys, but it's not getting much attention in OT so here it is: (I didn't make it)
1. The concept of "Windows" (The Graphical User Interface) was originally conceived at:
(a)Apple (b)Microsoft (c)Xerox (d)Tandy Labs
I didn't understand whether the question asks who invented the GUI or who invented the Windows-style of GUI.
14. Laser printers use what for "ink"?
(a)Carbon (b)Liquid (c)Thermal paper (d)Water
Is it carbon?
37. ISA slots typically transfer ___ bits.
(a)64 (b)16 (c)128 (d)4
38. PCI slots typically transfer ___ bits.
43. The location of expansion cards on a motherboard can significantly influence actual speed.
True or False
I said false because while the location can affect whether the card works fine or not at all, I don't think it significantly affects speed.
44. How many RAM (SIMM) Banks (minimum) does it take for a classic Pentium to be satisfied?
(a)1 (b)2 (c)4 (d)None of these
45. The recent Pentium (II/III) only require ___ RAM (SDRAM) memory modules to be satisfied.
46. For a typical parallel cable, how many pins does it have?
(a)9 (b)15 (c)25 (d)None of these
Is it 25?
51. (give the DOS command to) PATH the DOS, Windows, and Games directory.
I've never done that.
54. There is a 15 pin port on the back of the computer what could it be?
I'm too lazy to look. Is it serial port guys?
56. What are the possible errors when you get a "CMOS ERROR PLEASE RUN SETUP"? (need 2 answers)
58. Provide a metaphor or a simile for Cache on a processor?
72. How much Conventional RAM / Memory is there total on an IBM PC? ___
82. Which is Faster? (Assume they are all INTEL)
(a)486DX4-120 Mhz (b)Pentium 120 Mhz (c)Pentium 100 Mhz
I don't recognize the first one.
86. Windows 95 is primarily a ___ Bit Operating System.
I dunno... 32?
87. Win 3.11 has the acronym of (WFW). What does this stand for?
Is it Workspace for Windows or something like that?
88. What is the IRQ of a typical printer port?
89. What is the typical IRQ of COM2?
(a)IRQ3 (b)IRQ4 (c)IRQ2 (d)IRQ5
90. What is the typical COM port of a Bus Mouse?
(a)IRQ3 (b)COM 15 (c)IRQ 5 (d)None of these
I'm assuming b or d. Heh
92. The RISC Processor Chips are commonly seen in:
(a)Hard Drisk Drives (b)Pentium based computers (c)Printers
I dunno, I know my Dreamcast has one
97. Apple's chooser function is similar to Window's icon of ___
Fuji? Granny Smith? Gala?
98. In Novel what does the "rights" command do? ___
99a. Where could you find a UNIX Computer? ___
I dunno what Unix is for... is it for web servers?
99b. Which O/S would you use for an Internet Server? ___
Unix? Linux? Win2k?
100. What is the name (style or type) of the keyboard that we use today? ___
I didn't exactly understand what this question was asking.
101. Which is the older PC?
(a)IBM XT (b)IBM 286 AT (c)IBM PS/2 (d)IBM 386 SX
103. Which company first developed the Networking Concept and Model?
(a)Microsoft (b)3COM (c)Kingston (d)Xerox
I know 3Com makes network products... but were they first to develop the concept and model?
108. Cisco Corporation produces what type of computer equipment?
I forgot...
110. Pentium III Processor uses ___ number of data pipes / channels.
111. What is another name for the FPU?
I dunno if this counts as "another name" but I put Floating Point Unit.
117. If there are four of the 72 pin SIMM slots, what is the current maximum number of MB or RAM that can be installed?
(a)8 (b)32 MB (c)128 MB (d)1024 MB (e) 131 MB
120. Name two different types of pointing devices.
I don't understand this question. Is this asking for "laser pointer" and "mouse" or what?
122. What two files were commonly used to modify the boot sequence and configuration in DOS?
Is one of them autoexec.bat?
125. A printer speed is determined/measured by:
(a)CPS (b)DPI (c)RES (d)AST (e) CDROM
I think this is a mistake..... where is PPM????
126. Explain the main difference(s) between a 3COM 3C900-Combo NIC and the 3C905-TX NIC. (space for 2 answers)
umm.... winner gets a pat on the back. yay
Is it carbon?
True or False
Is it 25?
I dunno... 32?
Unix? Linux? Win2k?
