I just installed ECD Creator 5 Platinum for my Samsung 8x8x32x CD-RW and is it just me or is this the worst program ever imagined. It has almost no configurable options as compared to 4.0, but that is not my biggest concern. I tried burning a divx movie which is huge of course but it says that it needs enough space to buffer it in temporary files. I checked options and I can change the temp forlder but I can't disable it. Limiting the temp size also did not work. When it actualy burns it takes forever as I gues it has to make the buffer and it doesn't even use the buffer as I also tried to do a burn from a network computer and after half an our of copying the file to buffer it instantly gave me a buffer underrun, but actualy worked for 15 minutes or so finalizing the burn before it actualy stoped and gave me the errors. CD creator 4.0 is certenly not the best but it worked normaly on another computer I have, no buffereing no slowdowns, it just burns as instructed even though it can produce underrun errors if the source drive is slow but it is infenetly better then 5.0. Is there a way to fix 5.0 and disable the bffering and get to work normaly? (I tried the last vertion of Nero but it just would not install properly on the system.)
Thanks
Thanks
