Not sure what is going on here but no matter what adjustments I make in BIOS CPU is stuck at 2ghz with same multiplier and FSB.
I read that you had to update the bios on this board for E8400 to work properly, so I did that. Updated to version F8a which specifically says supports Wolfdale/ E8**** CPUs.
But after update nothing has changed, FSB, multiplier and such will change in BIOS, but using CPU-Z it shows it stuck at the same settings.
Ugh what is goin on!!!!!
http://i30.tinypic.com/whm7h1.jpg
