Originally posted by: kschaffner
ok so what is the difference between the e8400 and the e3110?
There is no difference, except that you can claim that your PC is a "high-end workstation" because it has a Xeon.
Originally posted by: aigomorla
Hi everyone well I just bought all of my other components however, since both the e8400 and e8500 are out of stock everywhere I was wondering which one would be better to get. I have the money for both but I was just wondering if the e8500 had any benefits over the e8400. Thanks, Kschaffner
E8400. But...
Forget that, buy the E3110 since some stores still don't know they are REALLY an E8400 just with better shipping voltages!
This statement holds a VERY VERY big YMMV tag. [Your millage may vary] Your vid is luck of the draw, the only gaurentee you have is that the chip will run @ its designed specs, as for overclocking, a Xeon will not gaurentee you a better overclock, nor will a QX or X processor.
almost nothing. Maybe and just maybe the xeons might be bin'd higher for stress reasons, but that be very small if any.
There basically the same chip, get whatever is cheaper is my 2 cents.
Originally posted by: boomhower
If you are on here and planning to buy a $200-$300 CPU and the supporting hardware for a new system and cannot afford another $5 on your light bill then you have your priorities seriously screwed up.
It seems we agree on most points here and we can just agree to disagree on the others.🙂
LOL... i have no comment for this....
My problem was the blanket statement that everyone will like it and could afford to own it.
I have never said everyone would like it. Although I do struggle with the thought of finding many people would be disappointed with a quad but I am sure there are some. Definitely the heat issue could be a deal breaker for some. Yes I will make the blanket statement that everyone can afford(that is considering an E8400, at most sites the Q is actually cheaper right now. If you are on here and planning to buy a $200-$300 CPU and the supporting hardware for a new system and cannot afford another $5 on your light bill then you have your priorities seriously screwed up.
Originally posted by: sofarfrome
The bottom line is this: Batch/FPO# is what counts.
fact1-I had an E8400 (Q743A) that would run 4.3GHz with 1.344vcore. P95 stable for 9+ hours and passed all 3D benchies.
fact2- I had an E8400 and E3110 (both Q746A534) that wouldn't run 4.3GHz stable no matter how much vcore you put to them and I tried up to 1.6vcore.
fact3- I currently have another E3110 (same batch as the previous two-Q746A534) that requires 1.456vcore to be 4.3GHz P95 stable.
So far, any mention of the Xeons being better as far as lower vcore required is untrue. Do they last longer? Dunno as I ran mine for a couple of years and sold them. Do they run hotter/cooler? Nope. In my water loop all of these recent CPUs have topped out at the same temps (+/- 2degC) when running P95 for 9+ hours. There is a lot of conjecture on all forums as to what makes the xeon different than the standard intel desktop chips. I have used xeons for my gaming and desktop rigs for years. Frankly I can't say that any xeon OCs better than its desktop counterpart. I had Xeon3060s with batch codes L629B and L631B that did not perform any differently than desktop cpus with the same batch codes. All would do 3.71GHz with 1.41vcore. Also, if you search around you will see the Q6600 and Xeon X3210 (both quads) of the same L723A batch code will typically OC better than most other batch codes. There are exceptions but that one sticks in my mind because I have an X3210 that runs 3.8GHz with 1.456 vcore. Under phase/dice/ln2 that may be a different story but under good air or water it is the same.
Right now it doesn't matter which one you buy. It does matter what batch/FPO# CPU you buy. That has always been true. And if you are lucky enough to find a Q743A I suggest buying it.
