- May 22, 2007
- 11,144
- 32
- 91
are you still at 1.6v or did you dial it down a bit when you went to 3.85? I had to use 1.64 in bios to get stable at 3.704, and even that I was afraid to run orthos for 24 hrs +.
damnit! he doesn't have his location info set up yet...he's probably gordon moore's grandson or something...
Originally posted by: jhl81
so out of all the chips i bought during those years i think i atleast deserve one good one right?damnit! he doesn't have his location info set up yet...he's probably gordon moore's grandson or something...![]()
Originally posted by: bryanW1995
why are you going for 7x500+ instead of max oc? Are you getting better voltages? Are you having trouble getting 8x438? You are putting a lot of unnecessary stress on your mobo right now, though it is kinda fun (or so I hear) to check out max stable fsb.
it's less stress to run 500Mhz 1:1 than 430Mhz 1:1.20
It seems to be more stable and require less voltage. Also Everest read, right and copy scores are much better.Originally posted by: bryanW1995
Less stress on what ?
It makes a difference to people in 2nd place.Originally posted by: cmdrdredd
After a certain point, depending on what you're doing there is a diminishing return on the speed. I mean. 3.6Ghz to 3.9Ghz is not that big of a difference all things considered.
ok, I´m up to 3600mhz stable, but the northbridge heatsink is really hot. Good news is my CPU only need 1.3875v ("vdroop" to 1.312v under load according to CPU-Z). If you want to avoid vdrop, dont buy a P35-DS3R i guess..
wow that 's alot of vdroop ... well i have a problem with the northbridge getting too hot as well on my 965p-ds3p but after i got a fan it made a hell of a difference its actually warm to touch (its not hot at all) ... and also coz i had no air going towards the mb aswell it made it hotter .... i can't fit an aftermarket heatsink coz of my tr ultra so this was my best solution but works and cools my cheap ram aswell and gets my mb temp down too ... notice i don't have the fan attached to the nb heatsink but still made a heap difference ....
see the link here to see how i got the fan ...
http://img504.imageshack.us/img504/5576/spa0165he6.jpg
this is what i'm at right now and even at that point of orthos the northbridge was warm not hot ... before i had this fan the northbridge was hot to touch even for a second ...
http://img411.imageshack.us/im...0mhzscreenshot5lt8.png
i think it was a good investment .... unless you already have cooling on it and its still that hot?
I do not have a NB fan but Im a bit worried my temps are too high anyway, if I look at the idle system temp in BIOS it says 47-48c even at stock speed 8x333 while the CPU temp is much lower. On the other hand, the system is stable in orthos even at 7x475. Everest reports much lower motherboard temps, around 32c idle.
