Originally posted by: EXEEMLITE
Hey Mark,
Could you tell me why you feel this way? My thinking is if a chip has already proven itself on another system and I have my 6400 going at 400 fsb. I would be able to slap the 6600 in , make a few adjustments and off I go. Can you give me a short explanation of why this is wrong? Thanks for you reply bu the way
Originally posted by: ziddey
lol you guys arent reading what OP wrote. Yes, you should be fine.
Yes we are reading... Unless the 6600 WAS at 3.6 on the other system, but that was not stated, and I don't ASSume anything. And I know that most 6600's won't do 3.6 on AIR.
Very few people get 3.5 or over on any Concoe on air cooling.
Originally posted by: Duvie
The guy is obviously qouting non coretemp which then pust my trust in his competence...So good luck...
Aslo remember people's definition of stable can really vary...
I would say non core temp temps of 49c means 60-64c in core temp.....
No ninja is going to give you 49c temps on a E6600 at 3.6ghz with core temp/TAT at orthos...sorry....
I have top of the line coolers and orthos is still high 50's low 60's on all systems..in cases...and that is with changing out the fan for a higher speed fan and turning off fan control....
NOw the OP has been pretty lame in leaving out a lot of important data, and his wording of this whole thread has left something to be desired...
Perhaps if you have some sort of super E6600 and you are giving it less then 1.37 under load and 1.425v at idle you may hit those but I still find that tough.
You have to admit those temps are not in line with others with similar line of coolers...
Sorry just as I see it....
I still dont see the Tuniq tower outdoing the ninja with a more powerful 120mm fan by that much.
I guess anything is possible and I will take your word for it....
The OP still has screwed this entire thread up, with his vague post.
See here: Info
I guess I am just seeing out of the ordinary results.
Originally posted by: Trader05
my e6600 at 3.6 now, 1.4v and a Ninja
is this in a case? ambient case and room temps?
By the wacky vcore on cpu_Z means it is actually 1.45v or greater like you said....
2min of orthos cant be the highest...I would expect that has to go up at least another 3-4c...I dont see max loads in orthos for hours...
