Originally posted by: WEW
If there is a like a $3 diff between the E2160 and E2180 - is it worth it to get the E2180? thanks
It would probably be easier to oc the E2180 since it has a 10x multiplier (the E2160 has a 9x multiplier). It depends on the motherboard you have; if your motherboard is good enough, you could push fsb further, and so it wouldn't really matter. Some people have said that E2160s OC the best out of the E2xxx series; whether there is any factual evidence to back this up, I don't know.
I would go for the E2180 if I were you, just because it would be probably be easier to oc with the 10x multiplier.
What motherboard would u be using it with? If you're using a motherboard you would have to use BSEL with, I would recommend the E2180, because then you wouldn't have to push fsb as much to get the speed you wanted, since pushing fsb may be a problem on cheaper motherboards.
You can ignore anything past this point, since it's not much help to you
_________________________________________________________________
I personally went with a pretty darn cheapo route, and I may sadly end up getting only what I paid for, but we'll see. I bought the E2200/ECS 945GCT-M/1333 cpu/mobo combo from Fry's for $78.99 ($85 with tax). I'm hoping to BSEL and do a Voltage mod to the processor to reach just under 3.0ghz. I'd say I'll have done pretty well for myself having only spent so little money.
But, I haven't assembled the system yet, or opened anything, so I may decide to sell the ECS motherboard and buy a Conroe1333 to do BSEL on that. The ECS motherboard doesn't have an option to change fsb, but the Conroe1333 does. I could do BSEL and then raise fsb from there to achieve a higher overclock. But, alas, there's still a chance I wouldn't be able to push my processor past 2.9ghz, so it may just be a waste of time.
I originally planned to buy a E2140 and a IP35-E, but the IP35-E has been OOS for so long. I managed to miss the deal with the rebate this month too
