DVR without Tivo, basically a VCR replacement with no montly fees
bob4432
11,727
46
i need a dvr that is basically a vcr replacement but don't want any extra features that i need to pay a monthly fee for. i would also like to be able to get the video out of it if possible. what can you recommend? would also like cheap ;)
bob4432
11,727
46
Originally posted by: RossMAN
Toshiba SD-H400 with FREE TIVO BASIC
What's the difference between Tivo Basic and Tivo Plus?
http://customersupport.tivo.com/knowbase/root/public/tv1199.htm
can you get tivo basic on all of the tivo/dvr recorders?
i don't want to spend much $$$ was looking at ebay for one. i could just use a vcr but after decent quality cable and dvds, vhs looks like sh!t. the only thing i use a vcr for is my video surveillance system, which is a industrial time lapse unite and i am just recording black and white vide
MustISO
12
Tivo branded recorders require a subscription. The Toshiba unit is one of the only devices that doesn't require a sub.
RossMAN
Grand Nagus
Feb 24, 2000
79,084
456
:thumbsup:
I bought the Toshiba SD-H400 from PriceGrabber.com since they are no longer sold in stores. I love the fact that it offers free tivo basic, that was my main reason for buying it.
bob4432
11,727
46
is there anything that is basically a vcr but instead of a tape it uses a hdd? no subscriptions at all?
isekii
28,578
Toshiba SDH-400
how many times do you need to be told.
The programming guide is free.
ChefJoe
2,506
Use old PC with a Hauppauge 150/250/500 card in it and BeyondTV as the software. If you have the old PC the other parts shouldn't be more than $200... maybe slightly more to get a big HD. You can record in MPG2 and then make DVDs with another piece of software.
RossMAN
Grand Nagus
Feb 24, 2000
79,084
456
Yes Toshiba SD-H400 and original ReplayTV 3060 (free lifetime subscription).
What's your price range? I'm thinking about selling my ReplayTV 3060 with NO MONTHLY FEES!
geckojohn
4,679
Costco has a dvr right now that records to a hard drive and DVD-r discs.. Has anyone tried this?
bob4432
11,727
46
Toshiba SDH-400
maybe i need to make this clearer - i need something cheap...
DeviousTrap
4,841
Toshiba SDH-400
How about you make something clear - what is your definition of cheap?
RossMAN
Grand Nagus
Feb 24, 2000
79,084
456
Toshiba SDH-400
$79.99
TV Tuner + Beyond TV license = free Tivo like PVR onto your hard drive :thumbsup:
bob4432
11,727
46
as far as an old pc i will have a 1GHz Athlon w/ 384MB of ram soon available as i upgrae my wifes machine, and i could put either a 30 or 60GB hdd in it. i don't need a lot of recording time and will not use it except one would with a vcr to schedule it to record certain channels on days x,y and z and don't want to make dvds. but i would need a remote...
are there any free programs that will do this? that will run on win2k or xp?
bob4432
11,727
46
Toshiba SDH-400
$79.99
how do those cards work? in the past i had a tuner card but i receive a ton of reception problems on the card, but a tv hooked up to the same line worked excellent.
isekii
28,578
Toshiba SDH-400
$79.99
Oh man... this sounds sweet.
Anyone wanna order one and have it sent to me ? ;)
I have satellite currently.
I don't need an additional box ?
I can just get signal and record and what not ?
ChefJoe
2,506
I ran Beyond TV on win2k without major problem. You're going to be recording at sub-dvd watchable resolutions if you go with a software based card (I think happauge's hardware based ones cost at least $70) and you're going to have to fiddle with the resolution a whole bunch to not peg the cpu. I used a p3 1.1 ghz with 500 mb of ram for a long time with a software based card. If I had it to do over again I would have bought the hardware based encoding card right away and avoided all the diddling around.
1 last thing, are you wanting to watch and keep or just watch later ? in my experience, software based cards are going to record looking like a long-play vhs tape was used. The extra processing you can do with hardware based cards (which I use in my beyond TV box now) allows for a better picture to be recorded.
bob4432
11,727
46
do you know if the 150 is a hardware based card? i don't know anything about these. also, it will be just to record now and then watch later. the tv is a 480i set and will use either rga or s-vhs to get back into the tv.
thanks for the info
RossMAN
Grand Nagus
Feb 24, 2000
79,084
456
Toshiba SDH-400
$79.99
What's your TV reception source?
If you have cable or satellite you should be ok. If you're using OTA antenna, that's another story.
