DVI cable.
Thuban
45
I'm buying an LCD monitor for the first time. It doesn't come with a DVI cable so I think I need to buy one. My question is when it come to DVI cable, do you get what you pay for or any cheap $10 cable will do?
Sonikku
15,906
4,930
The latter.
Don't buy into Monster Cable's Super Supreme Fiber-Injected Pixie Dust of Perfect Pwnage shielding BS.
brewty
601
I bought a 15' DVI cable for my 2005FPW from monoprice.com that works well.
Josh7289
799
I just got that six foot Link Depot one from Newegg. Works great for me. I haven't noticed any problems.
jimbob200521
4,108
29
there may be a .0000000000000003567% differance between the $10 cheapie and the monster cable, ahh, cable, but for some, that little diff is worth the $80+ price tag
Doctorweir
1,689
Right...the signals are digital anyway, so why bother shielding? It takes a lot of noise to make a 0 look like a 1 and vv... ;)
An analogue connections however...
Rommels
290
Ordered THIS DVI-D from monoprice.com monday got here today.
The cable is about half an inch thick it looks like and the quality looks great.
For $10.76 + $6 shipping it's a deal thats worth it.
Golgatha
12,404
1,078
Yeah, it's kinda like buying a super high end fiber optic cable. Sure you get a bit better transmission, but it is still just a 1 or 0. As long as the signal arrives; you're fine.
unclebud
5,518
radio shack had some on clearance for $12.49 also. maybe some stores still have them in stock
cohenfive
949
does the same logic apply to hdmi cables? i'm going to be setting up an lcd tv for hdtv and face the same question--get a servicable cable or a great cable.
Golgatha
12,404
1,078
HDMI is a digital signal as well. You'll get very little to no better performance out of a high end cable.
