Works like a charmyou could use DVDFab Decrypter to make a file rip that will not trip up DVD Shrink.
Originally posted by: Queasy
RipIt4Me - Uses DVDDecrypter and DVDShrink. I've yet to see a DVD that it can't rip that DVD Decrypter or DVDShrink had problems with.
Originally posted by: doan
Any new apps (free) to replace DVDshrink? I use AnyDVD in the background for decoding and then DVDshrink to remove menus, etc. Some recent Sony DVD's crash DVDShrink. I tried nero recode but its not as good as DVDshrink.
Originally posted by: scott
RipIt4Me in conjuction with DVD Decrypter and Fix vts.
Then, at least for me, it's WinAVI converter to change .avi to DVD.
Then DVD Shrink.
Then just prior to burning I usually defrag the folder containing the DVD files. This is probably unnecessary, but it seems to result in fewer bad burns & useless coaster disks.
Tried DVDFab Decrypter for awhile, didn't like it. Went back to RipIt4Me + Fix VTS.
Originally posted by: bruceb
DVDFAB Platinum can handle the Sony DVD with no problems
and you get a choice of wether or not to keep the menu when
you use it to make a copy ... the developer iis constantly makling
updates to account for changes in anticopy measures
It is not free, but it does come with Free Lifetime Upgrades
www.dvdfab.com
RipIt4Me 1.70 no longer needs FixVTS installed, contains some changes that should result in less players balking at the removal of small cells, offers to switch back to full movie mode if an episodic disc is detected and the mode has been set to movie only and there are some other minor improvements and bugfixes.
That's really sad about RipIt4Me.RipIt4Me appears to be the latest software to fall victim to the entertainment industry's crackdown on our rights - the site went down an April 1st, and statements by the admin of Digital Digest seem to confirm that RipIt4Me is no more. So here's my plea to those who write software: even if you don't want to release your source code, please make sure that in case something happens there's a way that development can continue. I'll gladly offer to hold sources for safe keeping so that in case something happens the software can continue to live as open source.
www.dvdfab.com
i was just looking at DVDFAB....trying to decide to buy it or just buy CloneDVD to go with ANYDVD that I already own.
Originally posted by: CZroe
No. I did a fresh download of RipIt4Me from their home site last night, so it was still up as ofRipIt4Me ...<cut> - the site went down an April 1st...<cut>
8Apr07.
I have another use for FixVTS not connected with RipIt4Me, so I still find it useful.
If someone has an .AVI file and converts it to DVD, the FixVTS can be run on the converted file before it is burned to DVD.
