Hi, I ran into a big big problem! My DVD (Pioneer DVD-303S 6X SCSI Slot load) stopped working. I am running Win2k & ME dualboot (shouldn't matter...) but it won't work at all. Both 2k & ME recognize my drive perfectly, so does my initio (INI-9100U or something like that) scsi adapter recognizes it fine. It also accepts and ejects cds/dvds fine, but when I try to read it, it says theres no disk inside. And if I try to boot from CD, it will say 'drive not ready'....... I know it was working fine awhile ago, haven't used it recently in a few days but today before I found out it wasn't working, I tried to install CDRWIN 3.8a beta on my Win2k setup. It asked for ASPI drivers and i said go ahead and install them, afterwards it completed fine, but when I tried to run CDRWIN, it crashed my system.... so I uninstalled it and reinstalled it without the ASPI and it worked fine, I even burned a CD. Then I tried using my DVD-ROM to read CDS/DVDS both and found it wasnt working, so I suspect something with cdrwin messed it up, I Found this ASPILOG.TXT in my root dir created recently so I'm thinking this could be a clue, but I have NO IDEA what it means... maybe someone can help me? or offer me suggestions? I checked all the basics, jumpers, cables, etc. and it SHOULD work, but it doesnt 🙁 .......... Please help!!! I don't want to have to buy a new drive!
Thanks
agee@ucla.edu
Here's the ASPILOG.TXT file:
NT version information:
Major version = 5
Minor version = 0
Build number = 2195
Platform ID = 2
Service Pack 1
( 3) Scanning "\\.\Scsi0:"
( 8) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 0"
Error = 2
( 9) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 0"
Error = 2
(10) Driver = "atapi"
( 3) Scanning "\\.\Scsi1:"
( 8) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 1"
Error = 2
( 9) Error reading Registry for "Hardware\DeviceMap\SCSI\SCSI Port 1"
Error = 2
( 3) Scanning "\\.\Scsi2:"
(10) Driver = "ini910u"
( 4) Discovered 3 SCSI ports
(13) length = 6199
(14) D:
(17) "\\.\D:" is at SCSI Port 1 Bus 0 Target 0 Lun 0
(20) Driver = "atapi"
Type = "DiskPeripheral"
(14) STORAGE#RemovableMedia#7&28c17b5d&0&RM#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}
(14) NDIS
(14) {0E70EF07-C8A0-4205-BE59-183B718864A9}
(15) Error opening "\\.\{0E70EF07-C8A0-4205-BE59-183B718864A9}"
Error = 50
(14) DISPLAY1
(15) Error opening "\\.\DISPLAY1"
Error = 5
(14) IDE#DiskMaxtor_90845D4__________________________GAS54112#3441393153594333202020202020202020202020#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
(17) "\\.\IDE#DiskMaxtor_90845D4__________________________GAS54112#3441393153594333202020202020202020202020#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}" is at SCSI Port 1 Bus 0 Target 1 Lun 0
(14) SCSI#CdRom&Ven_PIONEER&Prod_DVD-ROM_DVD-303&Rev_1.06#4&111885af&0&020#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}
(17) "\\.\SCSI#CdRom&Ven_PIONEER&Prod_DVD-ROM_DVD-303&Rev_1.06#4&111885af&0&020#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}" is at SCSI Port 2 Bus 0 Target 2 Lun 0
(20) Driver = "ini910u"
Type = "CdRomPeripheral"
(xx) New device handle on existing adapter
About to send "\\.\SCSI#CdRom&Ven_PIONEER&Prod_DVD-ROM_DVD-303&Rev_1.06#4&111885af&0&020#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}" into the pipe ...
CallNamedPipe failed
Error = 2
(14) DISPLAY2
(15) Error opening "\\.\DISPLAY2"
Error = 5
(14) Root#SYSTEM#0000#{65e8773e-8f56-11d0-a3b9-00a0c9223196}
(14) WsdrvTest
(14) DmIoDaemon
(14) ACPI#PNP0C0C#2&daba3ff&0#{4afa3d53-74a7-11d0-be5e-00a0c9062857}
(14) Ip
(14) DISPLAY3
(15) Error opening "\\.\DISPLAY3"
Error = 5
(14) USB#Vid_03f0&Pid_1204#MY04M140JJJJ#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
(14) ACPI#PNP0303#4&244b3c61&0#{4afa3d53-74a7-11d0-be5e-00a0c9062857}
(15) Error opening "\\.\ACPI#PNP0303#4&244b3c61&0#{4afa3d53-74a7-11d0-be5e-00a0c9062857}"
Error = 5
(14) E:
(17) "\\.\E:" is at SCSI Port 1 Bus 0 Target 1 Lun 0
(14) IPSECDev
(14) Volume{bbc29ae1-8302-11d4-90de-005004d09272}
(17) "\\.\Volume{bbc29ae1-8302-11d4-90de-005004d09272}" is at SCSI Port 2 Bus 0 Target 4 Lun 0
About to send "\\.\Volume{bbc29ae1-8302-11d4-90de-005004d09272}" into the pipe ...
Error = 2
(14) Root#MS_NDISWANIP#0000#{ad498944-762f-11d0-8dcb-00c04fc3358c}
(14) NDPROXY
(14) $VDMLPT1
(14) Root#SYSTEM#0000#{3c0d501a-140b-11d1-b40f-00a0c9223196}
(14) Volume{6ff5fe30-8206-11d4-b830-806d6172696f}
(14) F:
(14) Volume{6ff5fe33-8206-11d4-b830-806d6172696f}
(17) "\\.\Volume{6ff5fe33-8206-11d4-b830-806d6172696f}" is at SCSI Port 0 Bus 0 Target 0 Lun 0
(14) WMIDataDevice
(14) {F0683798-30A1-4E75-AE4B-F639A0A4B540}
(14) COM1
(14) PCI#VEN_1101&DEV_9500&SUBSYS_02029292&REV_02#3&61aaa01&0&58#{2accfe60-c130-11d2-b082-00a0c91efb8b}
(14) Root#SYSTEM#0000#{dff220f3-f70f-11d0-b917-00a0c9223196}
(14) COM2
(14) PIPE
(14) STORAGE#Volume#1&30a96598&0&Signature961EE10AOffset7E00Length1F7800800#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}
(17) "\\.\STORAGE#Volume#1&30a96598&0&Signature961EE10AOffset7E00Length1F7800800#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}" is at SCSI Port 1 Bus 0 Target 1 Lun 0
(14) Root#SYSTEM#0000#{2eb07ea0-7e70-11d0-a5d6-28db04c10000}
(14) SW#{a7c7a5b0-5af3-11d1-9ced-00a024bf0407}#{9B365890-165F-11D0-A195-0020AFD156E4}#{d6c5066e-72c1-11d2-9755-0000f8004788}
(14) USB#ROOT_HUB#4&5741930&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
(14) {7720F2BF-3FF5-4745-92C1-EB0C4693466A}
(14) UNC
(14) CDR4VSD
(14) Root#SYSTEM#0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}
(14) HCD0
(14) USBSTOR#Disk&Ven_SanDisk&Prod_ImageMate_II&Rev_1.30#6&390f917b&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
(14) Root#MS_PTIMINIPORT#0000#{ad498944-762f-11d0-8dcb-00c04fc3358c}
(15) Error opening "\\.\Root#MS_PTIMINIPORT#0000#{ad498944-762f-11d0-8dcb-00c04fc3358c}"
Error = 50
(14) PRN
(14) PhysicalDrive0
(17) "\\.\PhysicalDrive0" is at SCSI Port 0 Bus 0 Target 0 Lun 0
(14) Root#SYSTEM#0000#{53172480-4791-11d0-a5d6-28db04c10000}
(14) CdRom0
(17) "\\.\CdRom0" is at SCSI Port 2 Bus 0 Target 2 Lun 0
(xx) Device handle already exists!
(xx) No previous drive letter, using existing device handle
(14) SCSI#CdRom&Ven_PLEXTOR&Prod_CD-R___PX-R820T&Rev_1.07#4&111885af&0&040#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}
(17) "\\.\SCSI#CdRom&Ven_PLEXTOR&Prod_CD-R___PX-R820T&Rev_1.07#4&111885af&0&040#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}" is at SCSI Port 2 Bus 0 Target 4 Lun 0
(14) sysaudio
(14) PhysicalDrive1
(17) "\\.\PhysicalDrive1" is at SCSI Port 1 Bus 0 Target 0 Lun 0
(14) fsWrap
(14) Root#SYSTEM#0000#{97ebaacb-95bd-11d0-a3ea-00a0c9223196}
(14) CDR4_2K
(14) CdRom1
(17) "\\.\CdRom1" is at SCSI Port 2 Bus 0 Target 4 Lun 0
(14) MbMmDp32
(14) PhysicalDrive2
(17) "\\.\PhysicalDrive2" is at SCSI Port 1 Bus 0 Target 1 Lun 0
(14) MF#PCI#VEN_12EB&DEV_0002&SUBSYS_008812EB&REV_FE#4&83da8fb&1&68#Child0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}
(15) Error opening "\\.\MF#PCI#VEN_12EB&DEV_0002&SUBSYS_008812EB&REV_FE#4&83da8fb&1&68#Child0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}"
Error = 2
(14) PhysicalDrive3
(14) ACPI#FixedButton#2&daba3ff&0#{4afa3d53-74a7-11d0-be5e-00a0c9062857}
(14) Global
(15) Error opening "\\.\Global"
Error = 6
(14) ACPI#PNP0F13#4&244b3c61&0#{f117b9b2-6e65-11d2-a148-00001c2053de}
(15) Error opening "\\.\ACPI#PNP0F13#4&244b3c61&0#{f117b9b2-6e65-11d2-a148-00001c2053de}"
Error = 5
(14) ACPI#PNP0501#1#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
(14) SW#{a7c7a5b0-5af3-11d1-9ced-00a024bf0407}#{9B365890-165F-11D0-A195-0020AFD156E4}#{d6c50671-72c1-11d2-9755-0000f8004788}
(14) PCI#VEN_10B7&DEV_9055&SUBSYS_905510B7&REV_64#3&61aaa01&0&50#{ad498944-762f-11d0-8dcb-00c04fc3358c}
(14) ACPI#PNP0501#2#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
(14) Root#SYSTEM#0000#{3e227e76-690d-11d2-8161-0000f8775bf1}
(14) Root#SYSTEM#0000#{ad809c00-7b88-11d0-a5d6-28db04c10000}
(14) SCSI#CdRom&Ven_PLEXTOR&Prod_CD-R___PX-R820T&Rev_1.07#4&111885af&0&040#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}
(17) "\\.\SCSI#CdRom&Ven_PLEXTOR&Prod_CD-R___PX-R820T&Rev_1.07#4&111885af&0&040#{53f5630d-b6bf-11d0-94f2-00a0c91efb8b}" is at SCSI Port 2 Bus 0 Target 4 Lun 0
(14) Root#SYSTEM#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}
(14) Volume{6ff5fe34-8206-11d4-b830-806d6172696f}
(17) "\\.\Volume{6ff5fe34-8206-11d4-b830-806d6172696f}" is at SCSI Port 1 Bus 0 Target 0 Lun 0
(14) Root#SYSTEM#0000#{085aff00-62ce-11cf-a5d6-28db04c10000}
(14) ACPI#PNP0501#1#{4d36e978-e325-11ce-bfc1-08002be10318}
(14) Lkbdhlpr
(15) Error opening "\\.\Lkbdhlpr"
Error = 5
(14) ACPI#PNP0401#4&244b3c61&0#{97f76ef0-f883-11d0-af1f-0000f800845c}
(14) MountPointManager
Thanks
agee@ucla.edu
Major version = 5
Minor version = 0
Build number = 2195
Platform ID = 2
Service Pack 1
Error = 2
Error = 2
Error = 2
Error = 2
(13) length = 6199
(14) D:
(14) NDIS
Error = 50
(14) DISPLAY1
Error = 5
Error = 2
(14) DISPLAY2
Error = 5
(14) WsdrvTest
(14) DmIoDaemon
(14) Ip
(14) DISPLAY3
Error = 5
Error = 5
(14) E:
(14) IPSECDev
Error = 2
(14) NDPROXY
(14) $VDMLPT1
(14) F:
(14) WMIDataDevice
(14) COM1
(14) COM2
(14) PIPE
(14) UNC
(14) CDR4VSD
(14) HCD0
Error = 50
(14) PRN
(14) PhysicalDrive0
(14) CdRom0
(14) sysaudio
(14) PhysicalDrive1
(14) fsWrap
(14) CDR4_2K
(14) CdRom1
(14) MbMmDp32
(14) PhysicalDrive2
Error = 2
(14) PhysicalDrive3
(14) Global
Error = 6
Error = 5
(14) Lkbdhlpr
Error = 5
