DVD-R & DVD+R, $1/platter, shipped.
I just checked a 25 pack of Memorex DVD+R bought at BestBuy a few weeks back and they are as follows
Unique Disc Identifier : [DVD+R:RICOHJPN-R01-02]
Disc Type : [DVD+R]
Manufacturer ID : [RICOHJPN]
Media Type ID : [R01]
Product Revision : [02]
Disc Application Code : [General Purpose]
Recording Speeds : [2.4x - 4x]
Blank Disc Capacity : [Not Supported By Method 2]
[DVD Identifier - http://DVD.Identifier.CDfreaks.com
They say made it Taiwan with Part Number 3202 5571. Not sure if this makes a difference...so FWIW.
PM the $24.99 at OM to BestBuy (Has for $29.99) and save another $.50
Disc Type : [DVD+R]
Did you have to use the disc first to get the CD ID? Dvd can't identify it unless it is burned.
No - you DO NOT have to burn it for it to be identified. Alcohol 120% and DVD Decrypter also allow to verify media type.
Anyone have a cache of the OD 4X imations? I ordered them and they are NOT 4X... and the link no longer shows 4X anymore! They are Ritek G03's which is ok but the site DID SAY 4X at the time I ordered.... they changed it after.
