Originally posted by: elecrzy
16x write or read speed will spin the dvd up to 10krpm(only hq discs will las)t...similar to 52x cd burning speed.
Originally posted by: blackinches
blackinches says get the upcoming plextor slot loading burner.
Originally posted by: impemonk
My friend's HP blew up my Starcraft CD back in the day... The damage was so detrimental that the actual HP system no longer functioned lol. It turned out that my friend had installed a JG I20 under his cd rom when he first got his computer (somewhat of a bomb...) to kill his system should he get angry at it. THing was, it went off randomly and killed his entire system, burned his right hand, and killed my SC cd... hahahahah man it was the best. Long live 1998!!!!!!!
Originally posted by: ssvegeta1010
Jeez... Thats strange, but it could certaintly make an effective copy protection method. "Now with Exploding disc technology"
Originally posted by: SkyBum
UPDATE:
I took apart the drive one more time and inspected it further. I found a small tear (about 1/8") on the ribbon cable right where it connects to the laser assembly. I would imagine this could be repaired but for a $70 drive, the expense would likely be more than a replacement. It's definitely not something that I could do. The cable has a connector at the laser assembly but the other end is soldered to the board so an easy cable replacement is out of the question.
I just ordered a Plextor PX-716SA from NewEgg for $121 shipped. Didnt really want to spend that much but this Sata drive got my attention.
Sure, hope I've seen the last of the exploding discs for awhile....
The compatibility list contains a limited number of motherboards (and PCI cards) supporting SATA or SATA RAID that have been factory tested with the Plextor PX-712SA or PX-716SA drive. Your motherboard may not be on this list. This does not mean your motherboard will not work with the PX-712SA or PX-716SA, only that it has not been tested with the drive. Please consult your motherboard vendor web site and supporting documentation if you have configuration or driver questions.
Originally posted by: YOyoYOhowsDAjello
Oh, you posted a question now, that's nice
There's no harm in trying to clean it all up. If nothing scratched the lense inside and the alignment of everything is still ok, it might still work.
They did a mythbusters on this and they said that it was a myth. I knew that this had happened to people already and that it was something that actually happened. On the show, they ended up having to attach it to a super high rpm drill in order to get one to explode. Maybe the media they were using was too high quality.
I'm also thinking if there was a little crack in the disk already it would really make it a lot easier to break apart.
Good luck with the drive![]()
Don't say that man.. they might just do that.. engineer the actual discs, to potentially fragment if exposed to the higher disc-spin speeds used for ripping. Would certainly give new meaning to the "rip lock" feature of some drives, they could rename that feature to "shatter proof", keeping the speeds below 2X read speeds, to keep your purchased discs from self-destructing on you.
I saw this as well. And they said that for an average disc you would have to crank up the rpm's to get it to break. But the one in many million may be very weak and break by normal use. It was a myth because it was so unlikely to happen.
