dunking
miniMUNCH
4,159
I"m about 6'1" maybe 6'2" in the morning...and I used to be able throw down hard...now since I'm outta shape I can't...it would take me 2-3 months to get into good dunking shape again.
I'll say this...if you can touch the rim now...you could be dunking in 4 months by doing some hardocre plyometric training. Below is general outline...you should really buy a book on plyometrics cause there's a lot to 'em.
Key Excercises to do:
1)Squats - do some really heavy weight but only go down about a 1/4 - 1/3 of the normal squat (i.e. butt hitting heels)...basically stop when your thigh and shin bone form a 120 deg angle...try to do the uplift as fast as you can and then calf raise at the end of the rep. Then do some light weight...like 135 lbs or so...and do jump squats...literally try to jump as high as you can at the end of each rep...alternate full-all-thel-way down and 1/3 squats.
2) Box jumps - like Spoon and some other guys said and like your doing with the strength shoes...the shoes are a gimick I hate to tell you...not that there all bad, they help not to cheat. Start by just doing 'depth jumps': step/jump off 2-3 foot box and try to land as soft as possible (do not let your heal touch the ground) like Bruce Lee or a cat, or something. Do those for a few weeks to get your leg muscles used to the stress and then start actually trying to 'rebound jump' off the ground right as you hit...like a kangaroo. Try to minimize your actual ground time as much as possible. Later on you can add depth jumps and then box jumps from higher elevations to the end of your routine as the exist height becomes easy...and believe me, it will. You also add variety like changing direction when you hit the ground, etc.
The next thing you'll want to add is a medcine ball toss -or- if you have access to dumbell weights that's good too. Get like a 10 lbs medicine ball and go out to open area. Using an underhand, granny shot type of motion, heave the ball into the air as high as you can. Then try to catch it...but don't just catch it...imagine that your back and arms are a kind of spring in tension...and when you catch the ball it will just spring right back into the air...again the idea is minimize the time the ball spends in your hands. This excercise will train your explosive fast twitch muscles in your lower back and side as well as your shoulders...you literally can 2-3 inches on your vert just with excercise alone.
Finally...add some jump rope and running and bounding plyometrics...there lots of good track and field technique books that teach all this stuff really well.
I went through two cycle of this kind of training at two times in my life: once in HS and once in college...both time I added at least 6 inches onto my standing vertical and about 9 or 10 inches onto my running vertical and to be honest, I could got even more if kept at it but a 34" vert puts you a long way into the air and in most settings...no one can really even touch that kinda of ups.
slpaulson
4,414
14
I'm 5'8" and I can hang on the rim but I can't dunk a full sized basketball. Maybe a tennis ball lol.
madmacks
589
havent read this whole thread but to answer your quesion on strength shoes is that they DO work. its like working out anything else. if you lift weights you will get bigger and stronger. if you do strength shoes and plyometrics you will be quicker, faster, and jump higher.
ive never had the drive to do my strength shoes regularly but when i was in college i would do them the day before a game or even the morning of and it would definately make my legs lighter and youll get that adrenaline rush feeling as if you are walking on air.
cool stuff. im 5'10" and ive never dunked... never can get the ball to fall in but ive blocked a few people off the backboard :D
edit: one more thing. if you cant afford strength shoes a simple thing you can are the plyometrics mentioned above and just to simpley WALK ON YOUR TOES ALL DAY. yeah, people will make fun of you and girls might think you are gay (not that there is anything wrong with that :p) but youll definately jump higher. its true.
BuckleDownBen
Banned
Jun 11, 2001
519
You need to be able to jump up and touch a spot about 8 inches higher than the rim to be able to dunk a basketball. Its a lot harder to jump when you're holding a ball and you need some extra height to curl the ball over the rim.
You said something implying that you wanted to dunk to make a basketball team. To be honest, jumping is somewhat overrated when it comes to basketball, unless you can dunk the ball with some authority with two hands and without taking any steps. I haven't seen anyone under about 6'5" do this. The guy that can touch the top of the square will not be able to do that if I box him out. He won't be able to block my shot, because I'll give him a pump fake. If you want to dunk for the sake of dunking, then by all means go for it. If you want to be a better basketball player, work on your jump shot, endurance, and fundamentals. Height, strength, an outside shot, quickness, hustle, fundamentals, and the ability to see the court are all more important than jumping ability. Look at Jordan. He can't jump at all now, but is still very effective.
CrazyDe1
3,089
you guys are neglecting one very very thing...usually you have to be black to jump
you can't really do too much to improve your vertical...you might be able to improve it a couple inches, but probably not anymore than that...I'm 5'9" and used to be able to get my wrist on the rim but then I jacked up my knee and I can barely get the top of my fingers on the rim now...anyways...if you're under 6' and you're not black...i'd pretty much give up any hope of dunkin
bonk102
5,473
if your 6 feet tall and in any kind of playing shape, you should be able to dunk no problem. Before i put on 25 pounds when i came to college i could touch the rim and have dunked twice in my life, mind you, i'm only 5'10", and was never in the "best" of shape and i still did it, so i think anyone 6 feet or above can
Alex
6,995
thx for all of the input!!
theres so many of you that i dont think i can even drop a few names here... :eek:
to the guy that gave that comprehensive list of exercises, thx ill give those a shot! :) i just dont want to overwork myself too much cuz my ankle is pretty weak still. itll get 2 months of recovery though from now till i start workin out seriously.
about the team i wanna join, well i want to try out for the college bball team... the dunking or jumping high would just balance out my meager height (5'11). the workout in 2 months includes very specific bball skills too btw :)
FYI im not black but contrary to what that one dude said im pretty sure ill succeed if i put in the time and effort... i suppose black people are perhaps more genetically argh i forget the word, like able to jump high (no offense, this is a legitimate point!!) but frankly i think white men can too dunk :D
