lol its so minimalistic it grows on you the longer you look at it.
Feels like its a stripped down gutted macpro case.
Going on there site it looks like a macpro case. (dune)
Mac Pro:
Price tag is 200 dollars, so its not that bad in price either, but its crowd funded which is a big flag for me IMO.
But a case usually works or it doesn't so its not like you really need support unless its not working from the start.
Added note, i can see the case maker running to serious legal issues with APPLE in regards to this, so if you can get one, id get one ASAP.
But the construction seems solid, i would definitely be interested in one, as it has that professional MAC look.
I think my issue with this case would be it looks like if you have a front mount radiator, the fans have to be used in a pull configuration, which typically sucks for efficiency. And the top center mount power button kind of sucks, especially if you have cats they may get on top of it.
But otherwise it looks to be very high quality with a nice esthetic.
I think they made a classic mistake in the rear exhaust. The spots above the motherboard seem to be designed for 2x60mm (or possibly 2x80mm) fans. I mean, that is just ridiculous for a case that supports E-ATX, this isn't the 90's.
