dumb wiring question
NL5
3,286
12
Maybe i missed it, but i didn't see the non neutral version..
There is a link in my post above to a non neutral switch/dimmer/wifi. Would leave you with manual control as well as Wi-Fi.
Or, you could just add this to the light if it's feasible - https://www.amazon.com/gp/aw/d/B071...ifi+switch&dpPl=1&dpID=31DESJCFesL&ref=plSrch
Or, a third choice would be to wire your device in the lights jbox. Then just abandon the wires going to the switch and put a blank cover on it.
slag
10,473
dont want to change the switch and these bulbs are candleabra base, so that wont work. Plus, the fixtures are pretty small and I have LED bulbs in them. The solution has to be around 10 bucks or its not going to happen.
