Originally posted by: bob4432
thanks for the response, are my memory fsb/memory numbers correct? with pc2100 can i run a 533MHz fsb chip?
what is a memory devider?
The 865 is dual channel. It is the same (for all intents and purposes) as the 875 chipset. The 875 boards usually have a larger feature set. The only difference is you will lose the "PAT" capabilities on an 865 board if you change memory ratios. That is of course unless you have an Intel board which never enabled "PAT" on the 865 chipset.i865 is the cheaper non dual channel version
Yes you can run a 533Mhz chip with 2100. The bandwidth will be matched. This isn't a new purchase is it?
The divider will hinder performance only in the fact that yoor memory will be the limiting factor in your system. Odds are however you will not max out the bandwidth allowed by the 2100. My advice is to get an 800Mhz chip and an Abit IS7. Then use the divider to adjust for your slower memory. What is your budget?
I second that, get a 2.4C and a i865 mobo.
another dumb question - where do i get these dividers and do they effect reliability?
this board?
please bear with me, i feel like a rucking fetard about this, i went into the bios on the board i have now - biostar m7ncdpro (nvidia2 ultra400) and can't find anything regarding a memory divider. is it called memory divider in the bios?
thanks
according to the benchmarks i have read, i should get ~50% increase in encoding with a 2.8cP4 over a athlon xp 2000. that would be nice![]()
so the 800MHz/2.8c chip will still run at 2.8GHz, but the link to the memory will be cut down to 133MHz instead of 200MHz? am i following this correctly?
Originally posted by: Tabb
Another dumb question, how do these memory dividers actually work? Mathmattically?
Why does overclocking interfere with a Non-locked PCI Bus?
