cheuyungphat
- Aug 12, 2000
- 166
- 0
- 0
ThePrIsMcAURA,
I would hold off buying the via motherboard for a bit. I have seen so many mememory benchmarks that demonstrate the lack in ability for the via chipset in this area. Its not a "poor" board, just not really a "great" performer. Right now I am using (albeit - old
Epox KP6-BS with two PII (yes...pentium II's) 300's clocked to 450. These are slot one cpu's and I have a ball! For "funsies" I can throw 12 windows of MS media player up on the screen-each playing a separate .avi file, play a favorite cd, surf the web and play a game all without a hicup - try that with a single cpu! (and I am using old cpu's!
. I posted this link from www.2cpu.com that VERIFIES the ability of the intel 815E chipset as being SMP (dual processor) capable!!! EVERYONE always believed that the 815E (BX replacement for intel) was not SMP capable...well now I guess it is. A dual motherboard with this chipset would probably out-perform the Via chipsets to some degree (just read about the differences between Via and 815E from various sites). I will post the link about the dual 815E below. What I am anxious for is the Dual AMD chipset (760 I believe). A thunderbird dualie??? Mean machine. I have seen many rendering benchmarks that show how the Athlon kicks some major boo-taa--tee with regards to 3d rendering. Ill even post a link comparing Mac's G4 cpu to Athlon to Intel for rendering. Good luck with your decision...just don't be too anxious to pick something up right away as something better may be right around the corner... Take care!
Whoops! I missed your post about the Asus P2B-DS - very nice board, but...it only has 4pci slots...not a problem if you don't have a lot of pci cards. The new 815E boards should be able to overclock better (voltage adjustment hopefully). I believe -from reading the posts @2cpu.com that only the Asus board has the 1/4 pci clock divider (so you can make it to 133 fsb without the pci cards pooping out - especially the creative labs live audio board). Then again you shouldn't really be too concerned with overclocking if you are going to be doing video work - you don't wanna drop frames due to instability. Geeze! Decisions...Decisions...Decisions!!! Good luck!
Dual Processor Capable 815E Chipset:
Mac G4 vs. Pentium III vs. Athlon:
