dual monitor card for work
w0lf42
I'm looking for a good video card to use at work. I won't play any games. I'm interested in image quality and features.
I've heard that Matrox makes good cards.
Any Suggestions?
Any Suggestions?
Sounds like you've got things covered right there. :beer:
G550 should be a good balance, and supports Dual-DVI if you need it.
- M4H
Just a related question. My radeon 9800np came with a DVI -> analog converter, if I use that, can I plug in 2 analog monitors into the card?
Yes you can. The lowest Radeon that can do that is the Radeon-VE aka 7000. You just cannot use two CRTs _and_ the TV-out at the same time.
I have a Albatron GeForce 4 Ti4200P Turbo (nvidia) (installed in both Win2K and WinXP systems) with two analog monitors. I too, used the the DVI -> analog converter for the secondary monitor with no problems.
I know it's not a ATI Radeon 9800np, but I assume it should work just the same.
