Dual HDD MacBook Pro for $10 + cost of harddrive!
did you disable spotlight on the 2nd drive? - show us the dump that shows the sata speed and trim please 🙂
No Trim enabled. I still need to do that. Also I don't want to disable to spotlight on the 2nd drive.
Edit: Done
Nope no need. I'v moved iTunes and my Aperture library there. I about to move my steam folder there too.
So you can actually move the steam library now? Or is this an unsupported move with symlinks and whatnot?
well I was talking to a friend last night and he said if you install steam on the other drive it will install to that drive. I'm going to give that a shot. If that does't work I'll use the unsupported method you mentioned.
Moving the Steam library is pretty easy. Since I run FileVault on 10.6 (~ level encryption), I wanted my games outside of the encrypted volume for performance reasons (this is pre-SSD for me).
By default, Steam places everything under ~/Library/Application Support/Steam, I think. I moved that all to /Library/Application Support/Steam and symlinked from the original.
However, it broke when Steam updated at one point. I didn't fix it, I just reinstalled to the default location since I had an SSD now.
How do you install an application to a different drive? I didn't know you could install anywhere other than the /Applications directory on the boot volume without tricks.
Choice one is to download MarkDouma.com SourceFinagler app and follow the directions. The idea is that you are 1)moving your Steam Apps folder to a new location and then 2) using this app to create a symbolic link that goes into your Steam folder. I tested this application in June 2011 and it worked well. This is by far the easiest and quickest method.- Hunt'n.
http://guides.macrumors.com/Symbolic_Link_(Fixing_Steam_Content)
You just drag the Steam app from the installer to drive 2. <- that did not work.
I have a late 2008 first generation unibody MacBook Pro. I bought an optical bay adapter and stuck a 120GB SSD in there earlier this year. I love the performance i get with the SSD. Rather than copying over my entire user folder, I used symbolic links for my Downloads, Music, and the Steam folder inside the Library, since those are what take up most of the space on my machine. I also put my virtual machines on the platter drive, but I didn't need symbolic links for that. The reason I did this, rather than just putting my user folder on the platter drive, was that the Library folder definitely benefits from faster access times.
