Info Dual EPYC 7601 build. Comments and questions ?
Markfw
May 16, 2002
27,364
16,197
So, here is is. Dual EPYC 7601 32 core CPU's and 256 gig ECC registered DDR4 2666 ram, with a 1 tb NVME and a 2 tb spinner drive. 128 threads of greatness ! About $3400 for 2 CPU's, memory and the motherboard. About the same prices (and possibly performance) of the new 3970x. But I do have 8 memory channels. Then again, it only runs at 2400 mhz. But it only runs 50c 100% loaded. I can see why they run so slow after seeing the manual and the 1u heatsinks they were intended to run using.
Trotador22
22
Nice!, you can try with cTDP=225 but 2700Mhz is the best official all cores boost you will get.
If you want to overclock beyond specs you have to use ZenStates, go here https://forums.servethehome.com/index.php?threads/overclock-your-amd-epyc.23422/, you can go to post 115 to start seeing what you need for your setup.
My H11DSI dual EPYC 7551 is currently at 3 GHz all cores in Rosetta and also crunching Milkyway in a Radeon VII. At these clock/voltages the CPU vrm temperature becomes the critical/limiting factor. You'd better installing Supermicro Superdoctor utility to monitor all your board/cpu sensors. The problem of your setup (and mine) is that the coolers do not let room enough to put a fan powerful enough onto the Cpuvrms heatsink (between both cpu sockets). The thread linked has lots of information you will enjoy.
Your CPU utilization graph looks strange to me, in my systems it used to be a flat line at the 100% utilisation level. Rosetta is currently not stressing a lot CPUs, with WCG MCM I could not go much beyond 2.6 GHz before going above 90ºC in the CPUvrms. CPUs themselves are OK with fans at 1500rpm. So you have to check depending of the project.
Hitman928
6,750
12,478
OK, with my cooling, I entered 220. I saw 3000 once, but most of the time its only holding 2600. Still way better than 2400.
Here is the current, 2700
Can you do
cat /proc/cpuinfo | grep MHz
In the terminal and post a screenshot of the printout?
Markfw
May 16, 2002
27,364
16,197
Can you do
Nothing. I also tried lower case mhz
But like I said lscpu say 2600 to 2700 consistently.
Edit: I removed the " | grep MHZ" and its just the output from lscpu. Its MHz.
Hitman928
6,750
12,478
Yeah, it's case sensitive. Doing it this way will just show you what each individual core is at, was just curious if every core was boosting the same amount.
StefanR5R
6,802
10,848
This shows the current clocks of all CPUs:
cat /sys/devices/system/cpu/cpufreq/policy*/scaling_cur_freq
This condenses above output to the fastest and slowest:
cat /sys/devices/system/cpu/cpufreq/policy*/scaling_cur_freq | sort | sed -e 1b -e '$!d'
(This works only if a cpufreq driver is loaded.)
Edit, using /proc instead:
grep MHz /proc/cpuinfo | cut -d: -f2 | sort | sed -e 1b -e '$!d'
Markfw
May 16, 2002
27,364
16,197
Thanks ! The slowest was like 2583 and the fastest was like 2623, very close.
