Hi guys I tried out and it seems able to sense both my LCD and TV. With the NVidia driver utility it allows me to separate the two screen with it's own native resolution. Then I can drag windows from my LCD all the way to my TV. So basically I can open a movie with WM and then drag it to the TV and do a full screen to watch it at my TV while I open up a full screen IE on my LCD for browsing.
However, now I have a problem, if I set my LCD as primary windows, then my TV (which is a not primary) can not display any RM movies. However, when I setup the TV as primary screen then it will play the RM movies but it means all windows will popup from the TV side since it's now a primary source. My point is whatever screen not set as primary, then it's not possible to display RM movies (the Real Player screen is blacked out). Does anyone have the same experience and can you solve the issue? Thanks for all the help. Now I am really happy with my LCD, TV set so I can watch movie while I browse with hooking up just one computer.
