Originally posted by: ocforums
Originally posted by: Markbnj
Well, I didn't say that FPS didn't matter as much. What I said was that it isn't the only thing that matters. Frames per second measures how fast the system can construct and render a frame of video. In a single threaded loop architecture (most current games) anything that slows down that loop will slow down the frames per second. But it's not quite that simple. Windows uses multiple threads in the 3d graphics and sound subsystems, and in the I/O layer, as examples. So you can be chugging along rendering 75 fps and have network updates lag, causing sprites to jump around on screen. You've still got high performance graphics, but you don't have an overall high performance game at that point. There are lots of other potential examples. These conditions will become more common as more games are designed for concurrent processing.
On the cpu question, think about it like this: at 50% utilization a given core is executing instructions just about as fast as it possibly can, because there are no bottlenecks; its utilization is way below max. Now imagine a unit of work. You can either hand the whole unit to a single processor, or divide it in half and hand each half to a seperate processor. If you do the latter then that unit of work will complete in roughly half the time. I think where you are getting confused is in thinking that 50% core utilization equates to 50% speed. It doesn't. The cpu is still chewing through instructions as fast as it can. It's just that it could chew through twice as many in the same amount of time, if the rest of the system could keep up.
I am a bit lost with this debate.Is it being said the dual core can process a thread twice as fast as a single core ? Thats just silly and proven totally incorrect .Matter of fact only because AMD has set 2 cores side by side and removed bus sharring have you finally got a dual cpu even close to a single core in game performance.
Sli 7800 GTX 535/1335
FX 57@ 3051
14270 3D 03
Sli GTX 535/1335
X2@ 3051
14011 3D 03
(Extreamoverclockers.com reference for above systems)
In a 3d 03 bench test of the above systems with hardware pretty equil the FX will score about 200 Points more then the X2.This shows the systems game ability to be almost equil.It has also been shown if you encode a video and play battlefield 2 at the same time the loss in FPS is as close to zero as you can get when using the X2,and the fx falls on its face totally . .
And with any single threaded app windows can not split the work unit up,What happens in a dual enviroment is the threads are load balanced as equially as possible,Meaning threads are sent to what ever processor is free to exicute them,Some threads take a tad longer to exicute then others and thats why you can never get an exact 50% load balance as well as having other apps that require processor time which also will be scheduled along with the games threads, making the 50% load almost never perfectly 50% to each core.
No matter what happens in the load balance all you can ever have per thread is the speed on 1 single core IE dual core at 2.5 means you can never have more then that 2.5 as a max speed per thread and when you add memory and cache sharing thats where you will get a bit of over head causing the dual core to be slightly slower then a single core in a game.
Additionally it is in the threads schedualing that you get the "Smoothness" everyone is mentioning,,And that is easy to explain because you have 2 cores to process threads thus removing the wait time when you are multitasking . . .
Can a dual core ever be twice as fast as a single core ? Not in a single threaded app,And in a multi threaded app expect up to 70% as a max speed increase but never expect a doubling of speed from a dual core and the 70% MAX increase very seldom,Usually 20% or so is what you get in real life when you are using a multithread app . .
