Originally posted by: DVad3r
WTF, that sucks ass then, I actually thought my sound card has decoders in it 🙁 Is there any way to get THX and DTS sound on your comp then? Perhaps by connecting your sound card to reciever then that to my klipsch speakers?
If you're going to get a receiver, ditch the klipsch promedias.
Even if you do connect your soundcard to your receiver, but it's still not going to give you DTS from a stereo signal. It will get you DTS neo6 as I've described above.
In order for you to get true DTS (or DD for that matter) the source material has to have been recorded in discrete channels for all the different speakers. On a DVD for example, if it supports DTS, there is a track for each speaker in your system. On music, there are only 2 tracks (left and right). There is NO WAY you're going to get true DTS from a stereo source.
The only thing that comes close is the soundcards that do realtime DD encoding (the soundstorm solutions and some newer cards like the
X-Mystique) but all they're doing if they output DD from a stereo source (I'm not sure on this) is they're doing a pro logic sort of decoding and then encoding that into DD.
