yhelothar
DSLRs are jumping into the territory of carrying around multiple lenses, right? Unless there's such thing as a DSLR (...within my budget) that literally does everything from macros to landscape shots without having to carrying around a bag of lenses and swap them around to snap a quick picture or two, I really don't want to go that route.
Basically I just want something that will take superior pictures than my Droid X without breaking the bank. I'm not a photographer, and very few of these pictures will ever be printed (which, if that was the goal, would involve an expensive professional IPS monitor, better printer, copy of Photoshop, etc. as well). I want a good self-contained camera that won't require me to carry around more than a couple of cables, spare batteries, and SD (perhaps CF) cards.
Let's put it this way: if an expensive DSLR with all the right supporting gear will get me photos "rated" at 9/10 or 10/10, and my current Droid X will get me something around 2/10 or 3/10, what's it going to take to get a 5/10 - 6/10 or so?
Thanks for the suggestions everyone. 🙂
There is such thing as a DSLR (...within my budget) that literally does everything from macros to landscape shots without having to carrying around a bag of lenses and swap them around to snap a quick picture or two. You can buy a superzoom lens for the DSLR and never have to change the lens for less than $350, but granted you might have to go used.
If you feel that 3-4x zoom is sufficient for your needs, which will do macro and landscape shots, and good portraits, the choice is easy. If you need a lot of zoom, which is more useful if you want to do wildlife photography where it doesn't permit you to walk close to the subject, then a lot of zoom would be of help.
Here is an example of a few DSLR options that you don't have to change the lens, and it's basically identical in ease of use and handling as the superzoom P&S. There are a lot more options out there if you're interested, and you could possibly get the whole set for less than $300 if you really shop around.
This used DSLR body, $150
http://cgi.ebay.com/Silver-DSLR-Can...242565?pt=Digital_Cameras&hash=item1c162eaf45
Or if you don't like ebay, you could get a refurb nikon D3000 for $300
http://www.adorama.com/INKD3000R.html
18-200mm(11x) zoom lens for $189 AR http://www.bhphotovideo.com/c/produc..._XR_Di_II.html , nikon version here http://www.bhphotovideo.com/c/produ...AF014NII_700_18_200mm_f_3_5_6_3_XR_Di_II.html
If you don't need all the zoom, you can get better image quality and better low light performance with this highly regarded 17-70mm(4x zoom lens) $210
http://cgi.ebay.com/Sigma-17-70mm-F2-8-4-5-DC-Macro-Canon-MINT-/320599791727?pt=Camera_Lenses&hash=item4aa53c986f
