randomrogue
- Jan 15, 2011
- 5,449
- 0
- 0
I don't really have one, but I can't imagine wanting to spend more than $1000 total on camera and lens(es) - I can always upgrade to a better camera body later on, once I get technically savvy.
A thousand dollar budget really limits me to crop sensors DSLRs, doesn't it? Honestly, if I can "get by" with a 1.6 crop factor with appropriate lenses, I don't really care (for the time being). I can really only know through experience how limiting the crop factor is, and that will come through owning and using the camera.
Just wondering though: with ALL cameras, WYSIWYG, right? I mean, it's not going to crop what I see in the viewfinder, is it? I understand the image presented by the viewfinder as being "already cropped".
You don't have a choice but to get a budget crop camera and some lenses. Get good lenses.
The difference between crop and full frame would not be that apparent to you. The things most noticeable are getting wider shots if you invest in a UWA lens and less noise. With your budget and for your use you'll be just fine buying a good lens (not sure which mm), a tripod, and a crop camera.
